Exhaust Manifold Install - Defender Source
Old September 8th, 2013, 11:28 AM
d90xjay's Avatar
d90xjay
J Phillips
1997 D90 SW
On my '97 I took my exhaust manifolds off since I had gaskets at the Y-pipe and engine side that needed to be replaced, now after media blasting the manifold, I'm ready to put them back on. Problem is, I'm not sure where the washer goes in the sequence of installing. I've searched but came up empty.
I could have swore that when I took the manifolds off the washer was right up against the engine side before the gasket and this just seems off to me.
Shouldn't it be this sequence:
Engine, gasket, washer, exhaust manifold, lock tab, then bolt?
Edit: Oops I meant Engine, gasket, exhaust manifold, washer, lock tab, then bolt?
Old September 8th, 2013, 12:00 PM
Grover's Avatar
Grover
Head, gasket, manifold,washer,Lock tab, bolt...
Good luck...
Cheers...
Old September 8th, 2013, 02:28 PM
d90xjay's Avatar
d90xjay
J Phillips
1997 D90 SW
Thanks all.
I been thinking about getting them ceramic coated, but have wondered how durable ceramic is versus cost. For now I had put Eastwood's manifold coating on them. Will see how long now until rust shows through again.
exhaust
exhaust manifold temp? MUDSUX Defender Technical Discussions 4 November 19th, 2009 08:43 AM
300Tdi exhaust manifold problems crown14 Defender Technical Discussions 12 July 8th, 2009 11:38 AM
Whistle noise from exhaust manifold? markurski Defender Technical Discussions 11 November 27th, 2007 08:39 PM
Cracked Exhaust Manifold jamieh64 Defender Technical Discussions 9 November 22nd, 2005 01:04 PM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
