Exhaust Manifold Helicoil Failed - Defender Source
Old October 7th, 2016, 11:44 AM
aosias's Avatar
aosias
Alexandra
1995 D90
I was re-fitting the exhaust manifold and the stud backed out. It looks like the exhaust manifold stud sheared at one point, a helicoil was used to repair it and then the broken stud was reused.
Attached photos of the hole, not great but it doesn't look like there is a sheared stud in there. Also a pic of the stud, the short side was in the head and the end is smooth and ground down, not jagged like it just sheared. Stud also has metal wrapped around it that came out with it.
My plan is to clean up the hole, install a new helicoil and a stud. Solid plan or am I missing something?
Any helicoil kit recommendations or just go with a metric kit off Amazon?
Alex
ID:	159208   Click image for larger version
Old October 7th, 2016, 11:54 AM
Head bolt or exhaust manifold stud? What are we discussing? What engine?
Old October 7th, 2016, 11:56 AM
carlosz's Avatar
carlosz
Carlos
may be the picture but it does not seem it was ever helicoiled..the stud is always short and the shavings suggest a simple stripped thread.
yes a rethread and heli coil should do wonders for your case.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old October 7th, 2016, 11:57 AM
aosias's Avatar
aosias
Alexandra
1995 D90
Sorry- exhaust manifold stud. Is my repair plan the right approach? 300tdi
Old October 7th, 2016, 12:03 PM
A correct helicoil should be fine assuming it has not already been helicoiled and failed.
Old October 7th, 2016, 12:04 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Thanks.
And if that is the case?
Will this kit work?
https://www.amazon.com/gp/product/B0...A10PRH2DFOVNA8
Old October 7th, 2016, 12:32 PM
Naplm00
Matthew
I much much prefer wurth time-sert over helicoil. You just need clearance to install it and it's pricey
Old October 7th, 2016, 12:52 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
if you have a fastenel shop near you they stock heli coils
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old October 7th, 2016, 02:15 PM
aosias's Avatar
aosias
Alexandra
1995 D90
This is what came out with the exhaust stud. It was threaded on the end of the stud. I would think if I had just stripped the thread it wouldn't be a uniform shape like this.
Old October 7th, 2016, 02:18 PM
Is it steel or aluminum? Check with a magnet.
Old October 7th, 2016, 02:24 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Steel
Should I get this:https://www.amazon.com/BIG-SERT-Time...9QHBCFY83J11BG
Not sure on what size to get to repair it.
Old October 7th, 2016, 07:15 PM
Naplm00
Matthew
Nope just get the standard time sert not the big sert. Big sert is for areas that are severely damaged or have been drilled out.
I mount my time serts with a high quality thread locker. It also helps to have a tap handle
I've never had one pull out, and I've used them for motorcycle cylinder studs previously
Old October 8th, 2016, 11:38 AM
Might be time to consider tapping it out to a larger size?
Old October 8th, 2016, 11:06 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Hadn't even considered that. Seems like the easiest option. I understand how to tap it, but what sizes do manifold studs come in? Do I just pick up a new stud at a local auto parts store?
Alex
Old October 8th, 2016, 11:09 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I would figure out the thread pitch and get the next step up.
Old October 8th, 2016, 11:25 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I believe it's m10x1.5. What would be the easiest to get locally? Assuming not metric.
coil, exhaust
FAILED Maryland Emissions test Flagg Defender Technical Discussions 47 April 22nd, 2015 03:27 PM
Failed Emissions! Defender_90 Defender Technical Discussions 16 May 2nd, 2012 03:32 AM
Emissions – failed Hydrocarbons PPM down_shift Defender Technical Discussions 5 October 20th, 2011 11:00 AM
Tail lights Failed and I got arrested!! RickM Defender Technical Discussions 8 April 21st, 2008 06:02 PM
Just failed an emissions test, suggestions? Hans Defender Technical Discussions 6 October 11th, 2004 12:12 AM
