Exhaust manifold gaskets - Defender Source
Old October 31st, 2015, 01:32 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Just picked up my heads from the machine shop after taking down the top end of my motor- I have almost unnatural thoughts about how nice the heads look after reconditioning!
Question is about the exhaust manifold reassembly. Is there a correct way to install the new metal exhaust gaskets? Connector bar (between two ports) up or down? Also, anyone reinstalling the bolt retaining metal? Those were the biggest PITA of the whole job, bending the retainers that is. I was actually surprised that after a good o/n soaking in pb blaster the bolts came out pretty easy... So maybe the nut retainers are a good thing? Thoughts....
Old October 31st, 2015, 02:14 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Just did the exhaust thing. I believe the correct orientation for the gaskets is with the connector on the bottom. I agree with you on the lock plates, they are a royal pain to unlock. I used lock washers on reassembly. Sadly I won't get to see how that does just yet. Turns out I have a blown head gasket so it's all got to come out again.
Old October 31st, 2015, 02:31 PM
If you skip the exhaust lock tabs the bolts will loosen up in very short order.I put the lock tab washer things in place but didn't bend the tabs yet. I just keep tightening them at every oil change. They are always loose.
Old October 31st, 2015, 02:33 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Thanks for the lock washers thought. Seems like a good plan. I've been following the thread about your woes as well. It sucks to take everything back out again but removing the heads isn't much further than what you've already done.
Old October 31st, 2015, 03:37 PM
Keep in mind traditional spring lock washers do not ever do anything.
Ceramic Coated Exhaust Manifolds w/Gaskets and Hardware Method PHX For Sale - Parts 6 October 1st, 2015 12:22 PM
Exhaust Gaskets? WeBeCinYa Defender Technical Discussions 5 June 4th, 2015 06:54 PM
exhaust manifold gaskets Grover Defender Technical Discussions 3 January 26th, 2012 03:57 PM
Cracked Exhaust Manifold jamieh64 Defender Technical Discussions 9 November 22nd, 2005 01:04 PM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
