exhaust manifold gaskets - Defender Source
Old April 25th, 2011, 09:12 PM
Grover's Avatar
Grover
Question exhaust manifold gaskets
...can these gaskets (the ones used between the exhaust manifolds and the heads) be re-used? I pulled mine and gaskets do not look deformed at all. Rather not buy new ones if I don't need to.
Cheers...
Old April 26th, 2011, 02:41 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
You'll kick yourself if they do leak when you're done. Put new ones on and be done with it unless you are made of time?
Old January 26th, 2012, 02:04 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
I couldn't find the answer using search, so... What are the best Exhaust manifold gaskets to use? All I've ever heard is not to use the "locking tabs" and I saw someone who used the DII manifold bolts and some spacers that looked like a good solution for making it significantly easier to get to the lower 4.
Opinions are greatly appreciated.
Old January 26th, 2012, 03:57 PM
I am particularly fond of the stainless sandwich type, but I always put on new.
exhaust, gas, gaskets
exhaust manifold temp? MUDSUX Defender Technical Discussions 4 November 19th, 2009 08:43 AM
300Tdi exhaust manifold problems crown14 Defender Technical Discussions 12 July 8th, 2009 11:38 AM
Whistle noise from exhaust manifold? markurski Defender Technical Discussions 11 November 27th, 2007 08:39 PM
Cracked Exhaust Manifold jamieh64 Defender Technical Discussions 9 November 22nd, 2005 01:04 PM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
