Exhaust manifold eaking bullhorn - Defender Source
Old May 4th, 2016, 06:45 PM
barjout
Marc Bourget
1996/Tdi DEFENDER 110
Hi, Last summer I replace my turbo on my 300 Tdi for a hybrid turbo from Bell auto services and and since then the left bull horn is leaking and spurting black soot in the engine bay. I tried muffler ciment from Kleen Flo and lately some extra high temp silicone but it's still leaking. Any suggestions on what I should use to stop that exhaust manifold leak? I was gonna use cold weld but the temperature is way too high for that. According to my Pyro gauge the highest the temp will go is 562 degre celcius or 1043 fahrenheit.
Old May 4th, 2016, 07:07 PM
Clean it up really well with sand paper and then wash both sides of the joint (it needs to come apart first). After dry use a good exhaust cement filling the gap. Let fully dry and then allow to hot slowly before allowing the turbo to come on boost.
Old May 4th, 2016, 07:11 PM
barjout
Marc Bourget
I did all that twice. Cleaned it with brake cleaner, let it cure and then started the engine at idle for 20 minutes then turned it off to let it cool but same results twice. Still leaking. What brand do you call a good exhaust cement?
Old May 4th, 2016, 07:14 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Always had good luck with this on my turbo cars upwards of 35-40psi.
http://www.amazon.com/Permatex-80697.../dp/B000HBNUDQ
Old May 4th, 2016, 07:16 PM
You took the joint apart and filled the whole void between the turbo and the pipe?
Old May 4th, 2016, 07:19 PM
barjout
Marc Bourget
But the temperature range is from 50-500 fahrenheit. It won't be enought as mine sometime sees 1042 fahrenheit do you think?
Old May 17th, 2016, 01:08 PM
kosma_r
Jarek Bednarczyk
1998
I have the same setup and the same problem. The cement was blown after 1 week. I wonder if new bullhorns will be better than old ones.
Old May 19th, 2016, 08:16 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I recently replaced my worn turbo and horns with new. The net cost after selling the old unit was immaterial. The point is the new components seem to have sealed fine with the muffler cement.
Old May 19th, 2016, 09:18 AM
you should be able to get to 720 C.
Old May 19th, 2016, 09:24 AM
Clay, post up what product we used. I think it was the Permatex stuff?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 19th, 2016, 08:31 PM
lrna04's Avatar
lrna04
Michael
1994 D90
Have you considered cut your own hi temp / pressure gasket? http://www.amazon.com/Mr-Gasket-9615.../dp/B00068OLEW
exhaust, horn
exhaust manifold alternatives J.5 Defender Technical Discussions 9 December 10th, 2008 01:46 PM
Whistle noise from exhaust manifold? markurski Defender Technical Discussions 11 November 27th, 2007 08:39 PM
exhaust manifold fire risk??! hlamar Defender Technical Discussions 2 August 2nd, 2006 08:00 AM
Cracked Exhaust Manifold jamieh64 Defender Technical Discussions 9 November 22nd, 2005 01:04 PM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
