exhaust manifold bolts - Defender Source
Old June 1st, 2005, 12:35 PM
scoloco's Avatar
scoloco
'94 D90 ST
In snooping around my engine compartment, I noticed one of the bolts that holds the exhaust manifold to the motor is missing (3.9 v8). Anything special about these bolts, or can I get something in particular from a hardware store? (if so, what size and type?)
tia
-scott
Old June 1st, 2005, 12:45 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Nothing special on the bolts, though I don't remember the threading. Just don't forget some anti-sieze when you put the new one in, didn't yours have the locking plates?
-Hans
My oil line fix
My 100k stopped odometer fix
Old June 1st, 2005, 01:06 PM
On many cars these bolts are typically bronze so they dont seize.
Old June 1st, 2005, 01:38 PM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
What do you suppose the chances are that your bolt is not missing, but rather has been broken off?
Old June 1st, 2005, 01:49 PM
scoloco's Avatar
scoloco
'94 D90 ST
Rod, thats a good point. The locking plate is still there, which I thought was puzzling. Next step would be to check. tnx!
Old June 1st, 2005, 02:43 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The bolts that I get from the dealer are not expensive and are bronze.
Old June 1st, 2005, 04:45 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
The bolts on mt 110 are steel & I plan on replacing wih hardware store bolts that are a little longer. I am also loosing the the locking tabs & going with lock washers. I have one infront of me now if you need anymore info.
Old June 1st, 2005, 05:23 PM
I'm sorry - the nuts are bronze - the "bolts" are actually studs. You can get a kit of high-strength stainless (made by NRP) for the rover v8 from Totally Stainless if you want to replace everything with super-spiffy stuff.
Old June 1st, 2005, 06:14 PM
Hans's Avatar
Hans
Hans Haase
Wow, looks like LR was pretty inconsistant on these . Steel Bolts, Bronze Bolts, Steel Studs and Bronze Nuts?
Mine are steel bolts, and had anti-seize compound on them from the factory.
-Hans
My oil line fix
Old June 1st, 2005, 08:57 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I can't belive that!!!!!!!!!! The Factory use antisneeze! NO WAY!
bolts, exhaust
exhaust manifold temp? MUDSUX Defender Technical Discussions 4 November 19th, 2009 08:43 AM
300Tdi exhaust manifold problems crown14 Defender Technical Discussions 12 July 8th, 2009 11:38 AM
Whistle noise from exhaust manifold? markurski Defender Technical Discussions 11 November 27th, 2007 08:39 PM
Cracked Exhaust Manifold jamieh64 Defender Technical Discussions 9 November 22nd, 2005 01:04 PM
Exhaust system bolts rover4x4 Defender Technical Discussions 2 May 7th, 2004 08:26 AM
