Exhaust manifold bolt size ? - Defender Source
Old July 20th, 2010, 02:40 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
anyone know the proper bolt size ,thread pitch , and length for the bolts that hold the exhaust manifolds to the 4.6 aluminum V8 block ? I'm using Range Rover P38 stainless steal tubular exhaust manifolds that are 10.3mm thick, and ordering either small cap head bolts or Allen headed cap bolts to make them easier to install and remove. The current ones I have a a little sort (18.2mm) and on the chart I'm looking at they are I believe an metric thread but they are smaller than M10 larger than M8 (leaves it in the 3/8" range )
Chris "V"
Old July 20th, 2010, 08:45 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
If you mean the manifold to head bolts then they're listed as 3/8" for the 4.0L so maybe the same for the 4.6.
Old July 21st, 2010, 12:33 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
diameter is 3/8, thread is 16, length I believe is 1.25 inches...
exhaust
Steering pump adj bolt size? DaveHuny Defender Technical Discussions 2 September 3rd, 2005 01:44 PM
Bolt size for Diff? UpnOver Defender Technical Discussions 3 July 5th, 2005 08:28 AM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
Throttle body size on a Thor manifold? Hans Defender Technical Discussions 1 March 10th, 2005 10:10 PM
