exhaust manifold alternatives - Defender Source
Old January 1st, 2008, 07:29 PM
J.5
Joe Zinter
Does anyone know of low profile , block hugger exhaust manifolds for the rover v8? I'm sticking a v8 in a series and before too much of the bulkhead gets trimmed away to accomodate the rover manifolds, I want to see if I have any other options. I bought (and returned) a pair of hedman headers... they were much wider than stock rover exhaust manifolds. Anything else out there? Thanks.
Old January 2nd, 2008, 12:01 AM
pendy's Avatar
pendy
jim pendleton
89'd90
D&D rover V8 specialist. Get a set used to stuff a RV8 in an MG car.
JP
legend in my own mind
Old January 20th, 2008, 09:04 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I don't know if these will fit better but they are said to be for the D90:
http://store.toddcosuspensions.com/larode90110h.html
Anyone out there running these?
Old January 21st, 2008, 08:22 AM
J.5
Joe Zinter
Thanks. I'll give them a ring. Hadn't seen these before.
Old January 29th, 2008, 02:13 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
I can't tell for sure, but those look like the Hedman's which require some modification to get them to work on a NAS D-90.
Old January 29th, 2008, 02:41 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I helped a buddy try to install the Toddcos a few months back; to make a long story short they didn't come anywhere near lining up with the Y pipe. In fairness, I can't say for certain that it wasn't due to the usual rover tolerances, but in this case they were WAY off. He wound up having a custom Y pipe bent up if I remember correctly.
Old January 29th, 2008, 03:41 PM
cbass's Avatar
cbass
Bradlee Duncan
Did the Toddco's clear the area between the frame and starter on the passenger side? that is the trouble spot with the Hedman's.
Old January 29th, 2008, 04:05 PM
Abrooks's Avatar
Abrooks
Tony Brooks
If I remember correctly, yes. However, they weren't even close to the Y pipe and I seem to remember it taking a LOT of finagaling to get them to line up with the holes in the block as well. Again, YMMV
Old January 29th, 2008, 08:02 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
Of course there is always this route... then they will definitely fit.
http://www.jegs.com/webapp/wcs/store...10002_55374_-1
I got your JEEP thing, now it hurts when I pee!!
Old December 10th, 2008, 01:46 PM
cbass's Avatar
cbass
Bradlee Duncan
I need your opinions guys (Pendy specifically) ... I bought a set of the block hugger headers from D&D fabrications and I swear they sent me two left hand headers. I called D&D and he had me look at the flanges on them. One had a "1" stamped and the other had a "2" stamped on it. He said that means one is left and one is right. However, they are identical in every way. The way I understand it, they should be mirror images of one another so that the collector pipe drops down in the same spot on either side (just rear of center to clear the motor mount). Both headers fit perfectly on the left hand side of the truck, but both run into the exact same issue on the right hand side of the truck. i.e. they both hit the motor mount in the same spot. He says there's nothing he can do if one has a 1 and the other has a 2. He told me when I bought them that I could not return them. See attached pics.
ID:	16795   Click image for larger version
exhaust
exhaust manifold temp? MUDSUX Defender Technical Discussions 4 November 19th, 2009 08:43 AM
300Tdi exhaust manifold problems crown14 Defender Technical Discussions 12 July 8th, 2009 11:38 AM
Whistle noise from exhaust manifold? markurski Defender Technical Discussions 11 November 27th, 2007 08:39 PM
Cracked Exhaust Manifold jamieh64 Defender Technical Discussions 9 November 22nd, 2005 01:04 PM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
