Exhaust Gaskets? - Defender Source
Old June 4th, 2015, 05:08 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Exhaust Gaskets?
Just got my Y pipe in from Magnaflow to replace the stock one. One thing it did not come with, the gaskets. Where can I find these locally? I know I can order from AB, but I wanted to get this on tomorrow.
Old June 4th, 2015, 05:19 PM
bjf's Avatar
bjf
barry f
94 ST #395
I got a set from the dealer. Not expensive and easy. Do yourself a favor and remove old y pipe before you go to the dealer. If you break a stud you won't have to make two trips.
Old June 4th, 2015, 05:27 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
I didn't want to take a chance in doing it myself with breaking a stud, so I'm going to have the local muffler shop throw it on. I didn't realize I needed 3 total gaskets, and I found a euro shop that can have them by lunch here tomorrow.
Did you have any trouble with yours doing it yourself Barry?
Old June 4th, 2015, 05:43 PM
bjf's Avatar
bjf
barry f
94 ST #395
Well I only removed mine because I was doing the clutch. I broke one stud I think. Pretty user we remove the right manifold to replace it so I got those gaskets too.
Old June 4th, 2015, 06:30 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Run the engine for a few till it gets warm and then shut it down and spray the studs/nuts while they are hot with HHS or PB and let it cool down. They will come right off.
Old June 4th, 2015, 06:54 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Also...is this the normal way to plug the two O2 sensors that I don't use? Came with bolts installed. My 94 only has 2 sensors so I assume this is the normal way to plug the others? Seems strange.
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
exhaust, gas, gaskets
exhaust manifold gaskets Grover Defender Technical Discussions 3 January 26th, 2012 03:57 PM
generic gaskets? vesparover Defender Technical Discussions 3 March 9th, 2006 09:23 PM
4.6 block, which gaskets? vesparover Defender Technical Discussions 0 March 6th, 2006 07:17 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
changed cam, all gaskets and now it won't run vesparover Defender Technical Discussions 4 July 24th, 2005 09:56 PM
