exhaust fumes inside cab! problem solved. - Page 2 - Defender Source
Old May 3rd, 2009, 10:22 AM
discoinjapan's Avatar
discoinjapan
Michael Bruzga
93 D1/ 94 D90 ST/96 D1
A friend of mine who has a Series did his behind the cab:
Old May 3rd, 2009, 11:29 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Good thing
Good thing this isn't disco web. They would have torn you a new one.
Old May 3rd, 2009, 04:26 PM
I agree keeping the exhaust under water will reduce the fumes, but that's probably tricky to do in NYC and hell on the truck!
Old May 3rd, 2009, 08:11 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
The exaust comes out the top in between the cab and whatever that is on the back. Still less gay than the OP.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 4th, 2009, 08:57 AM
LOL I missed that - but was generally just being a smartass there.
Old May 4th, 2009, 09:09 AM
discoinjapan
Michael Bruzga
Hes' since removed that thing!
Old May 8th, 2009, 09:45 PM
johnpiero
John Brancato
none
You guys are brutal...I hate you all.
I removed the stack and took your advise and cut the exhaust after ther muffler, before the rear axle and angled pipe down...now for the test drive
Old May 9th, 2009, 09:36 AM
John, I think you are kidding, but please take it all with a grain of salt if not. You'll see we are generally a pretty friendly and helpful bunch here.
I hope it works but to be honest if anything I'd expect this is going to make it worse. Let us know how it goes though!
Old May 10th, 2009, 09:53 PM
johnpiero
John Brancato
none
i don't really hate you, just kidding...you guys are truley extremely helpful.
here's the update. After removing the vertical pipe, I cut the exhaust just after the muffler, attached a 90 degree elbow and pointed the exhaust down. It didn't work. Then i tried exhausting out the side, just in front of the rear wheel...this was even worse.
I have one last idea: similar the picture from one of the replys, i'll try to exhaust just behind the cab with a vertical pipe. As long as it pipe is high enough above the cab, this should work and be much less obtrusive than the first mock-up.
I'll keep you all posted.
thanks again!
Old May 10th, 2009, 09:58 PM
Campbell's Avatar
Campbell
Rich Campbell
I don't get it?? Why is this even a problem?? Aren't the stock pipes long enough to get the fumes out the side. I never smelled this in my st. Is it just a fastback issue? Are you sure your exhust system is free of any leaks?
Old May 10th, 2009, 10:06 PM
discoinjapan
Michael Bruzga
X2. Are you sure their is nothing leaking up front from the manifold?
Old May 10th, 2009, 10:08 PM
johnpiero
John Brancato
none
Well, it's definilty not a leak because i didn't smell any fumes when i had that vertical pipe on. Too bad it looks so obtrusive.
I don't think it's a fast back issue either because even with the top off the smell is there and the aerodynamics on a fastback with a top removed, isn't all that differnet from another with it's top removed. Maybe my engine is just running really rich and smell is more noticable.
very weird.
Old May 11th, 2009, 08:24 AM
thanks again!
Don't do it man! I'll bet you'll get the same reaction from us as the first attempt
At this point I'd say meet up with another defender owner and sniff rear ends. It really does sound like the problem is that your engine is running poorly. I drove a heavily rutted road yesterday and something juggles loose and my engine started running really poorly, but before I realized it was running rough I could smell the fumes.
With the exhaust existing behind the rear wheel you shouldn't have any problems with fumes.
Old July 6th, 2009, 09:22 PM
johnpiero
John Brancato
none
I FINALLY finished up the exhaust pipe system, and happy to say it works fine...NO MORE FUMES in the cab
It may not look too subtle, but i like it and it sounds nice too. Kinda reminds me of a 18-wheeler set-up with stacks.
Just wanted to share a picture with you all and provide documentation in case someone runs into a similar problem in the future.
Btw, the top is not longer a fastback style...it's been tightened up to look like a cab style...pics to follow when colder weather rolls around and i put the top back on.
THANKS TO ALL FOR YOUR FEEDBACK!
Old July 6th, 2009, 09:30 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
What about in the winter when you put the top on?
Old July 7th, 2009, 07:19 AM
Looks like shit. You should find the real problem. Ive never smelled exhaust in any Defender Ive ridden in. Ive never smelled exhaust in any convertible vehicle Ive ridden in.
Old July 7th, 2009, 08:27 AM
Campbell's Avatar
Campbell
Rich Campbell
agree
You have to find the problem, and fix that. Doesn't that thing get HOT!!
Old July 7th, 2009, 08:32 AM
If its anything like my truck it will get hot enough to burn at a quick touch. Definitely think you are fighting a symptom not the cause and it looks terrible imo.
Old July 7th, 2009, 08:44 AM
john, stop messing with us. That is definitely photoshopped.
Old July 7th, 2009, 09:00 AM
This reminds me to get started on the 2WD conversion I've been wanting to do.
exhaust
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
new problem, exhaust maybe? artm Defender Technical Discussions 3 May 29th, 2005 08:34 PM
Wow, more exhaust woes. Hans Misc. Chit-Chat 14 May 27th, 2005 02:08 PM
The sweet smell of exhaust!! bd90 Defender Technical Discussions 2 February 1st, 2004 07:46 AM
