Since I purchased the D-90 two years ago I have dealt with excessive heat coming from the driver side foot well. However, there doesn’t seem to be any heat coming from the passenger side foot well. I was wondering if this is normal from your experience? Is the exaust system failing? I need help because it is very hot. Thanks so much
Chris, does it seem to be comming from any one spot? Is the floor getting hot or is it hot air? to the left of the fuse box is a hole going through the fire wall, I would check to see that it is plugged. You may also want to pull up the floor matts and make sure the floor is screwed down and secure (no gaps). I have also found allot of heat comes out of the seat boxes if the cover is not on tight.
I agree with Mike with checking around the area just to the left of the fuxe panel. In the summer time I have super hot air and in the winter cold air all blasting through a opening in the firewall where some cables go through. there should be a rubber gasket that helps plug that up.
I have never felt a draft down in the fool well, rather it's just extremely hot. I think it's coming up from the floor boards or trickling in from the hole in the firewall you mentioned. I will check it out and let you know what I discover. Thanks for the help!
I bought some outdoor carpet from Lowes and covered the seat box, floor and the transmission tunnel. It helped a lot with the heat and the noise................
The drivers side catalytic convertor is a LOT closer to the floorboard than on the passenger side, and those things get HOT HOT HOT. Might want to try putting some heat shielding between the cat and the floor.
Now that you mention it Hans I thin on the tunnel there is some kind of faom down there on the bottome side. Could this have been removed from yours Chris?
Try putting some heat shielding along the floor and firewall. I used some European brand that's escaping me, but Dynamat makes this as well. Unlike other vehicles, the Defender simply has none of the typical insulation. Placing this material over the floor, tunnel, and firewall underneath the rubber matting helps. You won't confuse it for a luxury car, but it no longer feels like a convection oven underneath the dash.
I get some warm drafts coming through from the drivers side seatbox cover - basically any place that isnt sealed up will admit warm air into the cabin.
I just picked up my D90 a few weeks back, and my feet are baking as well. I am really feeling it coming in from the opening above the clutch pedal. Should this be sealed up, or is there someting I should look for?
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
