Excessive exhaust 300 tdi - Defender Source
Old April 1st, 2012, 09:53 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Started the truck- got on the road. Started smoking wen I would accelerate. Has been doing this a bit when the engine is cold. Normally don't see much from the exhaust after it starts to warm up. Today it kept getting worse- to the point that it was just billowing smoke as I drove down the road and then constant but not bad at idle (red lights). But the truck would be surrounded in smoke at the light. Drove it 10 minutes tops- from start to stop. Let it sit for 30 minutes. Drove home no smoke. No loss of power or anything like that.
History: basically a new Tdi with all the work that has been done to the motor. Has 250 miles on it since the re-build, drove it 60 miles on the highway last week with no issues. At one point the turbo blew and was replaced before I got the truck back. This did cause it to puke oil out of the exhaust and so I have some residual oil in my tail pipe from this- but that has been there for the last 250 miles.
I did pressure wash the lower front end today- there was some oil on the frame so I wanted to wash it off and see if that was a new leak or an old one. Didn't wash the engine, just the frame and front wheels. Makes me think that somehow there was some water in the fuel that was burned out driving and that's why it didn't do it after sitting.
Thoughts?
Old April 1st, 2012, 11:22 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Was the smoke white or black ?
Old April 1st, 2012, 11:48 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Don't you have a fuel filter? The fuel filter and sedimenter (if you have one) should both prevent water from ever going into the engine.
Old April 2nd, 2012, 09:07 AM
aosias's Avatar
aosias
Alexandra
1995 D90
White not black. I do have a fuel filter.
Old April 2nd, 2012, 10:05 AM
open the drain on the fuel filter and see if you get any water coming out. I think the stock filter will only separate water to the point when it is full. Turbo blew on a new engine? What up with that?
Old April 2nd, 2012, 10:10 AM
aosias's Avatar
aosias
Alexandra
1995 D90
Thanks. Will try that.
Wasn't a new engine at the time, is basically new now.
Old April 2nd, 2012, 03:31 PM
The white smoke is likely incomplete combustion, running lean if you will. A likely culprit is a clogged full filter. It's surprising how fast a filter will clog up if something nasty gets into it. Diesel technicians, feel free to clarify or say something more productive, but when I see white smoke, I just change the filter. And make sure it's full of fuel and bled properly.
Old April 2nd, 2012, 03:36 PM
Just fill the filter up with a little ATF (basic type F) before putting it on, it'll clean everything out.
Old April 2nd, 2012, 07:52 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
White smoke is also an indication of water in the combustion chamber, via blown head gasket or cracked head or block. Smell the smoke and see if it smells like Radiator fluid. If so then that isn't good. Otherwise do as the guys said above and check the filter.
Land Rover 110
Old April 2nd, 2012, 09:33 PM
aosias's Avatar
aosias
Alexandra
1995 D90
It's not coolant. The motor was just completely rebuilt 250 miles ago so I can't imagine it would be a cracked head or block. Will be checking fuel filter tomorrow and then going from there.
Old April 2nd, 2012, 09:41 PM
a diesel mechanic friend of mine has a saying; white smoke is a fuel problem, black smoke is an air problem
Sorry you are having so many issues after spending so much money. What did the shifting problem turn out to be ? You have what many to consider to be the ultimate drive train for reliability.
Old April 2nd, 2012, 10:22 PM
Alex C's Avatar
Alex C
alex
1985 D90 200Tdi
Smoke
Check and make sure the vacuum advance is connected, their should be a small tube running from the top of the fuel pump to a T piece next to the turbo.
Have you checked the boost ?
Old April 2nd, 2012, 11:34 PM
aosias's Avatar
aosias
Alexandra
1995 D90
She hates me. That's the only explanation I have for this truck.
Transmission had a bad oil pump so it was running without any oil. Oops. Transmission was melted so it was replaced with another re-built one.
Hoping to figure out what the issue is tomorrow with the exhaust.
Old April 3rd, 2012, 07:43 AM
White smoke is unburned fuel. Fuel that gets in when combustion is not possible. Either too late in the compression cycle or there is not enough compression to ignite the fuel.
Check timing first.
Old April 4th, 2012, 12:49 PM
Capt Milks's Avatar
Capt Milks
Did you have the head pressure tested when you did the re-build?
Land Rover 110
Old April 4th, 2012, 12:58 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I believe it was pressure tested. Couldn't find a reason for this defiant behavior yesterday when we checked her out. Of course now she isn't doing it again. Figures right? She's my other toddler.
Old April 4th, 2012, 02:57 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
a diesel mechanic friend of mine has a saying; white smoke is a fuel problem, black smoke is an air problem.
Black smoke is too much fuel on a diesel - usually due to an "expert" tuning the injection pump for more power.
Mike Hammond
Old April 4th, 2012, 04:30 PM
IE not enough air/boost to match fueling. On a Detroit where there is no pump its usually because of insufficient air ; ie filter clogged, turbo stuck, intercooler plugged up etc. One of the 8 liter engines on my boat was smoking and he was right, the water cooled aftercooler was clogged with soot. Cleared it and she's 100% again.
Old April 4th, 2012, 04:41 PM
mikeslandrover
Mike Hammond
Ahh, I was assuming that the easy things would be checked first
Mike Hammond
300 tdi, exhaust, tdi
300 tdi exhaust trybul Defender Technical Discussions 3 May 6th, 2011 08:32 AM
ECR New SS Exhaust Kits Coming soon TDI Too TDI Guy Misc. Chit-Chat 19 October 22nd, 2004 05:16 AM
MTL prices in Mass, 300 Tdi oil artm Defender Technical Discussions 4 September 10th, 2004 11:45 AM
