Excessive Cam Bearing Wear? - Defender Source
Old October 18th, 2016, 08:01 PM
GM13's Avatar
GM13
Gene
'83 110 CSW
Looks wicked excessive to me but I don't know what "normal" wear looks like. What would cause this? Just the bearings disintegrating?
Old October 18th, 2016, 08:50 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Wow. I'll bet that's what mine looked like right before it walked down the camshaft and the engine made a sudden, but subtle noise and no longer ran.....
Email is
Same place, new dogs.
Old October 19th, 2016, 06:28 AM
Do you know if those are the original cam bearings?
Those look melty to me. No oil for long periods of time.
Old October 19th, 2016, 07:27 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
That is what an oil starved bearing looks like...
Old October 19th, 2016, 07:53 AM
Chris B
72 + D1 drivetrain =?
Look at the cracks!!!!! Toasted.
Old October 19th, 2016, 09:46 AM
GM13's Avatar
GM13
Gene
'83 110 CSW
Could oil pressure be within spec(checked at the filter housing) and the cam still be oil starved?
@Sonoros, I don't know if they are the bearings fitted by the factory, Turner said they are the original LR machined finish, so I assume they were in there since new and not replacement LR bearings.
New cam, retaining plate, tappet assemblies, pushrods are going in the new short block, just trying to figure out what may have gone on. Haven't pulled the pistons out yet, probably have an answer to the knock when I do.
Cv, bearing and swivel grease and bearing numbers. Naplm00 Defender Technical Discussions 18 September 30th, 2016 08:44 AM
Excessive front tire wear Ncrover725 Defender Technical Discussions 43 April 2nd, 2015 09:44 PM
Excessive heat coming from under the seats hillstrubl Defender Technical Discussions 20 August 29th, 2011 03:26 PM
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 12:03 AM
Excessive Cold Weather Exhaust boshea Defender Technical Discussions 3 January 9th, 2005 01:44 PM
