Excessive Blowby - Defender Source
Old June 18th, 2015, 09:04 PM
asif k.
Excessive Blowby
I had this problem after starting up a defender thats been sitting for a few months, 19j 2.5 td engine. Last time it ran it was fine. Very little smoke from exhaust on cold start which clears up so nothing abnormal there. Oil looks fine and coolant is full and clean but there is a lot of smoke from the oil filler cap. Is this a head gasket or piston rings? I would think a head gasket would mean more smoke from the exhaust and some coolant loss.
Old June 18th, 2015, 09:21 PM
It could be either but my money is on piston rings.
Old June 18th, 2015, 09:26 PM
asif k.
Thanks. 19j is garbage, I'll change the oil with 80% lucas at this point before scrapping the engine.
Old June 18th, 2015, 10:21 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
yep not good a oil change isn't fixing that unless it way overfilled but you would be risking a run away
No Mall crawler here
Old June 18th, 2015, 10:35 PM
asif k.
why would an oil change with lucas increase chances of a run away? its not overfilled right now, level is correct.
Old June 18th, 2015, 10:59 PM
Thinned oil will pass between the cylinder wall and the piston easier than at its regular viscosity. Either way PLEASE video the event. Diesel runaway videos rock as long as nobody gets hurt!
Old June 19th, 2015, 05:58 AM
Rings stuck in piston grooves. Unfortunately as said most of what would usuually work to free them will likely result in a runaway. I also vote for let it go and film it.
300 tdi excessive white smoke? Greenbull Defender Technical Discussions 39 December 30th, 2014 01:34 PM
Excessive exhaust 300 tdi aosias Defender Technical Discussions 18 April 4th, 2012 04:41 PM
Excessive heat coming from under the seats hillstrubl Defender Technical Discussions 20 August 29th, 2011 04:26 PM
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 01:03 AM
Excessive Cold Weather Exhaust boshea Defender Technical Discussions 3 January 9th, 2005 02:44 PM
