Ex Mod oil cooler to V8 110? - Defender Source
Old July 8th, 2009, 10:17 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Hi everyone,
I have been reading a lot about oil cooler lines on the newer Defenders but have not seen anything about the older 110's. I just acquired an 1983 V8 110 and it came with what looks like an Ex Mod Oil Cooler? I think the previous owner was going to put it on the truck but never got around to it. Can someone please tell me if this is possible? I am not sure it the cooler base is a direct bolt on, can I just remove my existing base and attach this? IF not I plan to use just the cooler itself and buy a sandwich plate. The problem with that is I do not know if the line fittings are the same as the ones found on the newer defenders so I can just buy the fittings from ECR. Thanks for any input.
ID:	20449   Click image for larger version
ID:	20451   Click image for larger version
MUDSUX
Old July 8th, 2009, 10:25 AM
That's an interesting part, but I'm not sure its for a v8 unless it bolts to the bottom of the oil pump housing. Moreover, I'm not sure its really necessary. IIRC the only military trucks that had v8's were for very heavy loads and this was probably intended for desert conditions.
Old July 8th, 2009, 02:39 PM
LRover's Avatar
LRover
J. Michael McCaig
When I put the 4.6 in my 110 I used a sandwhich plate and an aftermarket cooler just a little smaller than that one. I attached it to the supports in about the same place and ran the hoses underneath away from any heat source. Since your application is different than the later Defenders, any hydraulic shop should be able to make up custom hoses for you to go from the cooler to the sandwhich plate. I do tow a trailer so I thought that it would be a good idea to add the cooler on my 110.
Old July 8th, 2009, 07:46 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
That oil filter housing/cooler base looks the same as the one fitted to my Ex-Mod 2.5 NA diesel engine, so I suspect that is where it came from. Don't know if it will bolt up to a V8 though.
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old July 9th, 2009, 02:37 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Yeah, all military 90 & 110s (well, 99% of them) have the oil coolers, with the 2.5 diesel.
Just looked through my mil parts book, and it doesn't list one on the V8 (but that doesn't mean some wern't fitted... my parts book only covers certain contracts; specifications changed between contracts)
But you could just use the sandwich plate as used on the 3.9 V8, it just bolts behind the oil filter housing, then run the pipes to the front cooler.
Old July 9th, 2009, 05:11 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Thanks everyone. That saves me a lot of trouble. Now I know not to remove the base plate of my oil filter off. Can anyone verify if the fittings on the cooler itself is the same as the ones found on the radiators of the newer defenders? Thanks in advance
MUDSUX
110, mod, v8
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil cooler hoses rvrsrvc For Sale - Parts 116 October 16th, 2005 05:47 PM
External Oil Cooler jabber Defender Technical Discussions 3 August 21st, 2005 04:45 AM
