Ex MOD Filter Markings - Defender Source
Old May 17th, 2013, 05:43 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Safe to assume the "101311" written in sharpie on the fuel filter and now found on the bottom of the air filter are likely the last dates the military refreshed them?
Old May 17th, 2013, 06:19 PM
Michael110's Avatar
Michael110
Michael Dickin
1986 110 Tithonus - Now Sadly Sold
It would be a bit of an odd date, since usually we write dates as DDMMYY in the UK, meaning the it would have been replaced in the 13th month of the year, a bit special even for the MOD. If it were me I'd ignore all possible dates on service items and renew them anyway, you know for sure then.
Old May 17th, 2013, 06:54 PM
josh-man's Avatar
josh-man
joshua
It's actually 181011, but either way I totally agree and subscribe to the "start fresh" method... Which lead me to finding these identical numbers/dates on this stuff.
Old May 17th, 2013, 07:41 PM
18 Oct, 2011 is my guess.
Old May 17th, 2013, 07:43 PM
josh-man's Avatar
josh-man
joshua
Time to change EVERYTHING!! Lol
Old May 18th, 2013, 02:30 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Probably mileage (or kilometer-age, as MoD vehicles usually have KPH speedo's as UK maps are in metric meters, so makes map reading easier)
Old May 18th, 2013, 10:38 PM
josh-man's Avatar
josh-man
joshua
Must be date. Odometer is in kilometers but it reads 68,xxx kilometers. I ended up with a pretty low mileage/kilo ex mod truck for sure.
Old May 18th, 2013, 10:42 PM
jafir's Avatar
jafir
Jafir Elkurd
Mine read about 1000 KM. I guess sometimes they get replaced.
Rovahfarm shows a mph version for about $200 new, I've been tempted.... But not enough.
Old May 18th, 2013, 11:38 PM
Michael110's Avatar
Michael110
Michael Dickin
They get replaced fairly commonly. I see a lot of vendors selling 25yr old MOD Land Rovers claiming a few tens of thousands of KM on them. If you think about it its just not very likely that a land rover in military service will do only a couple of thousand KM a year. In actual fact with MOD vehicles mileage is completely irrelevant, and inspected condition is much more important. I very much doubt any military land rover leaves service with the same engine, gearbox, axles or even seats it was made with. The same type of parts yes, but the individual parts themselves no way. Mine came with 54,000km on the odometer, but I bet it's done closer to 200,000km.
Old May 18th, 2013, 11:49 PM
jafir's Avatar
jafir
Jafir Elkurd
Yep. And mine being a radio truck, the miles wouldn't matter much anyway as it would be sitting at fast idle for hours running the 24v generator, wearing the engine but gathering no miles. I know my engine was replaced, because there is a plate on it that says so. Other things obviously look newer than others, like you said, things like seats and ball joint.
New Air filter box for HS 2.8 engine Santiago Defender Technical Discussions 6 November 17th, 2016 04:33 AM
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
Oil Filter Craigd Defender Technical Discussions 9 July 26th, 2005 07:06 PM
Air Filter Box Upgrade- Help!! alkhalifa Defender Technical Discussions 59 October 19th, 2004 04:37 AM
Check your trans filter! {manual} Bowtracer Defender Technical Discussions 5 May 25th, 2004 10:32 AM
