Ex MOD door latches - Defender Source
Old November 24th, 2014, 12:03 AM
slacker
don slack
1986 ex mod 110
Ex MOD door latches
2 of 3 doors won't lock. Key moves in barrel and tab on inside moves but door does not lock. Looks like this 86 ex mod has the series III type anti burst latches. Does not look like much inside of these to repair, all the refs I have looked at treat them as a box not opened... Not excited to take it off not having any idea of what lies inside. Would I be better off just ordering new latches? Can I hope to use the barrels I already have? Or should I get 3 new barrels too? Any sage advice? Thanks!
Old November 25th, 2014, 10:56 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
SO.. I bet you a burger that what's happening is that your door isn't closed.
Unless the U latch is fully into its second detent, the lock won't lock. It'll just spring back. That's how I tell my kids to close the door. Yank it shut, until it locks.
There's a good deal of play in the door jamb. Loosen it up, move it out, shut the door... betcha it locks.
But yes, they are series "anti burst".
I don't know how to get the barrels out of them to rekey.
Old November 26th, 2014, 10:13 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi you can open the door and push the catch on the lock assy down to the 2nd latched position and then you should be able to turn the key to lock it.
it sounds like your latch is only getting to the 1st latch position.
The barrel is held into the barrel with the lock keyways and a small pin on the end of the barrel
To remove the barrel find the small hole in the barrel housing, you'll need to insert the key and then push a small rod into the hole to release the pin on the barrel assy, pull it all out with the key.
you can see the pin at the end of the barrel in this photo..
http://www.brit-car.co.uk/product.ph...urst_lock_s111
regards
Gren
Old November 26th, 2014, 10:25 AM
Interensting. One of my latches wont release except with alot of force. Out of adjusting ideas.....
Old November 26th, 2014, 09:02 PM
DefenderMd's Avatar
DefenderMd
Ben
How you mean... like you close the latch (push the u to facing down n) and when you pull the handle it doesn't spring up?
If so. It may be bent, or it may have come apart inside...
THAT.. sounds broken. I could swear I ran into the same thing at one point and ended up fixing it... but if I'm remembering the right time... it took welding. Building up and grinding something that had become worn.
I can't remember what it looked like, and not having door uppers at the time, I don't think I ever tried locking it.
Old November 27th, 2014, 08:38 PM
slacker
don slack
1986 ex mod 110
Def Md I owe u a burger. They all will lock. Thanks!
Old November 28th, 2014, 07:10 PM
DefenderMd's Avatar
DefenderMd
Ben
as it happens I will be passing through Anacortes next weekend...
oh wait no.. that's alexandria virgina on my way through washington DC....
Oh well.. buy a burger for your buddy on me on you.
Old November 28th, 2014, 10:16 PM
boswalt's Avatar
boswalt
Brian Oswalt
1988 exmod 110
Slacker - I'm up in bellingham. Let me know if you need a hand with anything
Old November 28th, 2014, 10:55 PM
DefenderMd's Avatar
DefenderMd
Ben
and when you get your doors all aligned and working well... come by and use that experience to do mine.
Old November 29th, 2014, 11:11 PM
My left door was popping open and wouldn't lock with the key. I had a spare mechanism and you guys motivated me to swap out my keyed tumbler into the spare and install it today. The door now solidly closes and locks. Thank you!
Old November 29th, 2014, 11:35 PM
DefenderMd's Avatar
DefenderMd
Ben
there's probably no way I can get a new lock cylinder to match my other 3 is there? I just picked up a rear door...
Old November 29th, 2014, 11:53 PM
I would guess that any competent locksmith could rekey the cylinder to match. If you need a tumbler I have one without a key.
Old November 30th, 2014, 12:04 AM
DefenderMd's Avatar
DefenderMd
Ben
eh.. maybe..
I don't know if they sell "blank" cylinders, or if there's parts needed to buy, but.. yea.. I've never actually engaged a locksmith. Always just a really decent key cutter.
door, door latch, mod
Front Door cards latches and strikers jjstahl3 For Sale - Parts 3 June 1st, 2012 01:31 PM
NAS Front Door Latches jjstahl3 Wanted 0 February 29th, 2012 03:03 PM
Door latches James Pierce Wanted 0 November 24th, 2010 05:14 PM
ST door latches, left and right Abrooks Wanted 3 July 11th, 2009 06:04 PM
Military Bonnet Latches jabber Misc. Chit-Chat 1 March 8th, 2005 12:01 PM
