Even another no heat question - Defender Source
Old January 14th, 2009, 03:23 PM
LB Defender
Eric Beth
94 Defender 90
Unhappy Even another no heat question
Here are the symptoms: Defroster works fine, but when the switch slides down to heater the fuse blows almost instantly.
Here is what I think: The ground to the heater is shorting somewhere.
Here is the question: Does this make sense? Has anyone else had this problem? Can I just run a new ground? If so from where to where?
Here in NY the wind chill is going down way below zero tonight. It sure would be nice to have heat.
Old January 15th, 2009, 11:30 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Short term get under the hood and disconnect the cable and move the heat duct manually.
sounds like the cable is grounding on the switch some how, It doesn’t make sense
Slider Question kellymoe Defender Technical Discussions 13 January 24th, 2006 04:52 AM
Heat question Campbell Defender Technical Discussions 8 January 3rd, 2005 08:58 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
