Euro Offset Steel Wheels - Defender Source
Old October 24th, 2007, 01:16 PM
GYM's Avatar
GYM
Gary
97 SW
Question Euro Offset Steel Wheels
I'm considering mounting LT 235/85 R16 BFG AT's on LR 5.5 J x 16 steel wheels that are Euro offset, (not NAS 110 style offset). Part number stamped on the wheels is RRC503600...
I am thinking about the 235/85 size because it is the same diameter as the stock 265/75R16, (no issue w/ speedo error.)
Is a 235/85 R tire too wide for a 5.5 inch rim?
Bigger question, am I likely to encounter any inside clearance / turning issues?
Wheel back spacing is approx 4 5/8 inches. (Stock height NAS '97 SW)
Any experiences/opinions much appreciated...
Old October 24th, 2007, 01:21 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I think a 6 1/2 rim is better, that's what I run - a LR Wolf rim (Also know ae nato rims) very strong and you can get tubed or tubeless versions
Mike Hammond
Old October 24th, 2007, 05:21 PM
It will be fine. It is probably the most common wheel/tire combo found on a Defender.
Old October 24th, 2007, 05:47 PM
mikeslandrover
Mike Hammond
235's are a bit wider & taller than 7.50R16's so the tyres might rub on full lock. Although I've got a set of 235's on wolf rims that rub on full lock - it just depends how your lock stops are set. Mine are all the way in for the best possible turning circle
Mike Hammond
Old October 24th, 2007, 08:02 PM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
I've run 235/85R16 tires for years on what you are calling the Euro sytle steel rims and they work fine though in a perfect world a 6" or 6.5" like the wolf/nato rim is better for the 235 size.
fs, steel wheels, wheel, wheels
5 33x12.5x 15s BFG MTs on trek outfitters steel wheels draaronr For Sale - Parts 4 June 9th, 2005 09:06 PM
6 Steel Wheels 15x7 arbik For Sale - Parts 2 April 7th, 2005 11:41 PM
110 steel wheels and tires artm For Sale - Parts 3 January 21st, 2005 09:06 PM
Steel wheels! TwisteD90 Wanted 0 November 2nd, 2004 02:11 PM
Are you using stock alloys or steel wheels? dave_lucas Misc. Chit-Chat 3 October 3rd, 2004 03:56 AM
