ESR2244- NAS 110 fuel tank emissions manifold - Defender Source
Old August 14th, 2015, 07:45 PM
3rovers's Avatar
3rovers
Dennis Yard
1993 NAS D-110 #55
Gentlemen,
Anyone have to track down one of these fuel tank emissions manifolds? It is the three valve device coming out the top side of the fuel tank.
Rovers North has the P/N on their website, but also says call for availability. Afraid it might be NLA.
Mine leaks raw fuel when the tank is filled. Don't want to try to take it off until I have a replacement, in case its too brittle and breaks up when moved.
Dennis Yard
Land Rover Club of San Diego
1993 NAS D-110 #55 (GNUTRUK)
2004 Disco II (DSCO DOG)
Old January 28th, 2016, 11:09 AM
mattarm's Avatar
mattarm
Matt
1993 D110
Dennis,
Any luck here. I am after the same part or some alternative.
Matt
Old January 28th, 2016, 01:14 PM
Is there a reason why the plastic small version from the 95+ can't be used?
Old January 30th, 2016, 10:51 PM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
Are you sure it is leaking from the manifold? My 93 110 had a leak when filled, it was a leaked caused by corrosion around the filler breaking tube connection on the tank.
Old January 30th, 2016, 11:47 PM
61rover's Avatar
61rover
John Crouse
These are very difficult to find. It took me several years to find one that came out of a diesel conversion. I almost gave up and started to fabricate.
Old January 31st, 2016, 07:49 AM
there's nothing to this device from as far as i could tell on mine. it's just a box with a couple inlets to allow condensation of fuel vapor and then it's return to the tank. very much like the tdi cyclone filter. its a particular shape, but i'm sure you could find aftermarket equivalent and come up with a mounting adapter for same bolt holes.
if you have a rotted one, this should be an easy duplication project for a decent fab shop.
Mark Kellgren
KM4BOR
Old January 31st, 2016, 07:56 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I used one from a Disco. They are hard to get to since they are inside the RR bodywork. I made a bracket and kept the one way valve that was on the disco. Seems to work.
Land Rover 110
Old January 31st, 2016, 08:04 AM
for petrols, the only thing about it that needs to work is for the emissions inspector in your state to see a box or can shaped thing somewhere with lines coming in and out. you have that and mission accomplished. no ECU to keep happy here folks.
Mark Kellgren
KM4BOR
110, fuel, fuel tank, nas, nas 110
STC1139 Fuel Tank Unit 90 w/ In Tank Pump 89Defender90 For Sale - Parts 0 March 28th, 2015 02:13 PM
NAS fuel tank with fit 94-97 NAS D90 budzny For Sale - Parts 10 August 27th, 2014 08:57 AM
Aluminum traction sand mats and aux fuel tank / water tank jonathon For Sale - Parts 7 December 11th, 2012 03:14 PM
Defender 90 Fuel tank - Disco 97 / 98 tank thpsmr Defender Technical Discussions 15 December 9th, 2011 11:44 AM
Diesel fuel tank vs. Gas tank Tyler Wirken Defender Technical Discussions 9 January 28th, 2010 07:25 AM
