Error Code 17? - Defender Source
Old December 9th, 2004, 09:53 AM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
Error Code 17?
Code 17 - Throttle potentiometer
What is this? How is it fixed?
Thanks!
Old December 9th, 2004, 11:04 AM
http://www.rangie.com/articles_topic...at=6&subCat=26
The TPS tells the ECU how far you have the throttle open, it is a variable resistor, it is next to the throttle and you can check it with an ohm meter and I don;t think they cost to much to replace. Check out the link for the full procedure.
Code 17 Question loved90 Defender Technical Discussions 3 December 22nd, 2011 05:14 PM
109 North on Rt 17 Heading into NY State.. TDI Guy Misc. Chit-Chat 3 December 5th, 2009 09:24 AM
17" rims Jase Defender Technical Discussions 20 September 9th, 2009 10:08 AM
Check Engine light, code 17 mchombeau Defender Technical Discussions 3 March 17th, 2004 06:12 PM
