Erratic Idling Problems - Defender Source
Old June 22nd, 2015, 08:33 AM
jyoungjr01's Avatar
jyoungjr01
95 D90
In my 95 d90 I have been having problems with the idling when stopping at lights, etc. At every stop the rpm's would be all over the place and eventually die out if I didn't keep it going by staying on the gas. I had the idle control valve replaced but now it dies out every time I push the clutch in when coming to a stop. Runs great when I am accelerating but when coming to a stop it dies out almost every time. I thought I would ask you guys for input on what the problem might be, what to look into etc.
Thanks for the help,
Old June 22nd, 2015, 08:40 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Originally Posted by jyoungjr01 View Post
In my 95 d90 I have been having problems with the idling when stopping at lights, etc. At every stop the rpm's would be all over the place and eventually die out if I didn't keep it going by staying on the gas. I had the idle control valve replaced but now it dies out every time I push the clutch in when coming to a stop. Runs great when I am accelerating but when coming to a stop it dies out almost every time. I thought I would ask you guys for input on what the problem might be, what to look into etc. Thanks for the help,
Check your vacuum lines but it still sounds like the stepper motor. Some work better than others (I settled on a used Lucas one that works better than the crap off ebay and whatever Advance Auto sells for the Astro van). Did you replace the stepper because of the same symptoms and was there any change? What was the make and part number of the stepper you used?
Old June 22nd, 2015, 09:34 AM
Grover's Avatar
Grover
Hmmm...I've had luck with the $15 IACV from Pep Boys. BWT is the brand I think.
Make sure the four terminals are clean, use dielectric grease.
Lastly, clean the valve port, it gets rather dirty over time.
Good luck,
Cheers...
Old June 22nd, 2015, 10:01 AM
How often do you drive your Defender? Mine had been doing this, after driving it back a forth to work for a week it is running (dare I say it) extremely well.
problems
Erratic Tachometer 61rover Defender Technical Discussions 6 February 12th, 2013 10:50 PM
Engine dies while idling Coug D90 Defender Technical Discussions 2 December 4th, 2010 01:36 PM
CEL light when idling rlynch356 Defender Technical Discussions 7 May 14th, 2010 12:59 PM
Erratic fuel gauge matthewwcarey Defender Technical Discussions 12 January 21st, 2008 02:36 PM
Erratic Oil and Temp Sensor Jon_Winningham Defender Technical Discussions 10 March 30th, 2007 09:27 PM
