Erratic fuel gauge - Defender Source
Old January 7th, 2008, 08:24 PM
matthewwcarey's Avatar
matthewwcarey
Matthew Carey
95 D90 SW349
Erratic fuel gauge
My fuel gauge on my 95SW is constantly bouncing all around with the fuel movement in the tank. It swings from empty to full in the matter of seconds. What kind of repair am I looking at?
Thanks Matthew
Old January 7th, 2008, 08:28 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
could be as simple as an electrical connection. That happened to me although that was on a RRC.
Old January 7th, 2008, 08:31 PM
matthewwcarey
Matthew Carey
95 D90 SW349
It seems to be with fuel movement, or if I'm on a hill of any kind. Would that be a connection or the sending unit?
Thanks Matthew
Old January 7th, 2008, 09:02 PM
AggieD90's Avatar
AggieD90
Kevin Collins
'95 AA Yellow & '97 Willow Green
Mine popped out of gear over the weekend and landed the tank pretty hard on a rock...now it thinks it's full all the time.
Same thing for me or other ideas?
Old January 7th, 2008, 10:47 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
Kevin,
It sounds like the float is just jammed up at the top somehow. I say drop the tank and pull the pump out to see if the float is ok.
Kris
Old January 8th, 2008, 01:49 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Matthew, Is it the stock gauge, or an aftermarket replacement?
Most aftermarket fuel gauges bounce around more than a sugar-fueled 5 year old in one of those inflatable houses. Always found it odd to that every OEM fuel gauge I've ever seen has some kind of dampening to slow it down, and almost no aftermarket gauges do.
Aggie, your issue sounds like a wire popped loose.
My oil line fix
My 100k stopped odometer fix
Old January 8th, 2008, 06:17 PM
matthewwcarey
Matthew Carey
95 D90 SW349
I just bought the D90 and it's my first so I'm not sure if it's original or not. Is there somthing I should look for?
Thanks for your help Matthew
Old January 9th, 2008, 12:18 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
I have a used fuel gauge thought it would work in the 97 it did not 95/94 are different. It's yours for shipping if you want to give it a shot. I can always use the defender Karma credits.
Old January 9th, 2008, 02:22 PM
AggieD90's Avatar
AggieD90
Kevin Collins
That's what I was thinking too...the ground wire probably came loose.
Old January 9th, 2008, 08:43 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
I think there was a bulletin when the 90s first came out about the erratic fuel guage. You might ask the dealer if they can pull up anything on it.
Old January 12th, 2008, 07:55 PM
matthewwcarey
Matthew Carey
95 D90 SW349
Thanks for all the info, I'm going to give a few tanks of fuel and see how it does. It seems to be improving now that it reached 1/2 of a tank.
Old January 12th, 2008, 08:02 PM
mines erratic, fucker goes from full to empty way to fast.
Old January 21st, 2008, 02:36 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
Never trusted mine. I go by the odometer. If I hit 185 miles, I will run out at the side of the road. When the tank is full, first 1/4 tank evaporates really fast. Next 1/2 tank really slow (lulls you into a ffalse sense od security) then last 1/4 speeds back up. If I hit the red zone, I have 3 miles to find gas. Oh, and at this point the gauge likes to bounce - just to F@^# with me for letting the tank get empty.
The joy of listening, feeling, and talking to your truck because IT DOES understand, even if your wife does not.
I'm contemplating thinking about thinking about it!
fuel
fuel gauge ohm range naeirie Defender Technical Discussions 35 September 6th, 2017 02:49 PM
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
Help wth Fuel Gauge (that works sometimes) ToyCrusher Defender Technical Discussions 14 October 20th, 2004 08:43 PM
