Equipe vs terrafirma bumper - Defender Source
Old February 26th, 2011, 03:01 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Hi guys,
Does anyone have one of the equipe bumpers like this:
http://www.lucky8llc.com/Products.asp?ProductID=2008
Or the terrafirma like this:
http://www.lucky8llc.com/Products.asp?ProductID=2408
Not sure why the huge price difference....don't think the skid plate is worth double. But it is pretty slick.
Just wondering if anyone has any opinions on these bumpers.
On another note, I dropped the exhaust and crossmember last night to get the auto trans filter replaced and to make the line install easier. Stock cooler went in pretty well. I think the lines will fit pretty well, just need to see about it's proximity to the exhaust. They look like they will be ok. I assume there are some clips that mount to the oil pan. Might need to make some supports. I searched rovers north and other, but can't seem to find any stock clips/mounts. Crossmember removal was, um, interesting. I started pounding it out, then later used a bottle jack and wood to spread the frame a couple mil to help it come out. I found that to be odd.
Thanks, Pete
Old February 26th, 2011, 06:06 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I've had both versions of the Equipe. Hands down the "Ferrari" of Rover bumpers and very well made.
Semper Fi!
Old February 27th, 2011, 11:45 AM
Broncoduecer
peter
D90
Cool. Thanks for the info.
What do people do with the turn signals....? Seems like an important thing to have.
Old February 27th, 2011, 01:00 PM
Wolf Fabrication
Sterling Archer
'08 D3
It's easy to reroute the turn signal wiring to your front parking/running lights. There are a few threads on this board on how to do it.
Semper Fi!
Old February 27th, 2011, 07:07 PM
mattarm's Avatar
mattarm
Matt
1993 D110
http://www.defendersource.com/forum/...ht=turn+signal
Old February 27th, 2011, 07:21 PM
Broncoduecer
peter
D90
Oh cool. Thanks guys.
I was also thinking of using the 1995 setup. Or I was looking at led strips. That might be kind of neat.
Old February 27th, 2011, 09:53 PM
Birdman's Avatar
Birdman
Chris Bird
1995 D90 ST #2046
Equip bumper
Originally Posted by Broncoduecer View Post
Hi guys,
Thanks, Pete
I have the Equip bumper & like it.
Old February 27th, 2011, 10:32 PM
Rugbier's Avatar
Rugbier
Gustavo
You have a lot of Equipe items on that 90
NO SIGNATURE
Old February 28th, 2011, 04:29 PM
Birdman's Avatar
Birdman
Chris Bird
1995 D90 ST #2046
I sure do. I have the PO to thank for that!
I added ARB lockers to the front & rear, had it re-gerared to 4.14, added station wagon doors, switched back to steel wheels & put bigger tires on it and switched to a grey Badger II that actually fits over the gutter kits (which I had powder coated). Other than that, it's the same as when it left you.
You coming out to Breckenridge in August? How's the ankle?
Old February 28th, 2011, 06:29 PM
Rugbier's Avatar
Rugbier
Gustavo
Give us some porn ..post a pic ( hard to drool from the one on the avatar )... it seems to look fantastic.
Glad you went back to steel, is like they belong in that 90. ( if I had my way, I will put steelies on the LR3 )
Ankle still bad... bad..I can handle short term clutching ( not for long periods )
NO SIGNATURE
Old February 28th, 2011, 06:33 PM
Broncoduecer
peter
D90
Yea it does look nice. I'm trying to get a hold of Justin as we speak. Just need to spec out a winch now .
Is that an equipe snorkel also? Are you running their rock sliders also?
Pete
Old February 28th, 2011, 07:45 PM
Wolf Fabrication
Sterling Archer
'08 D3
The only complaint I have about the Equipe bumpers is they are about an inch or two too narrow. This leaves your fender skins exposed to trees (don't ask). I welded some 1/2 plate steel to the ends to protect my fenders.
Semper Fi!
Old February 28th, 2011, 09:15 PM
I do. They both look like Disco or Jeep crap that doesn't belong anywhere near a proper Land Rover. The Rockware gives a great approach angle too, doesn't require cutting the grille to fit a winch, can take hits from trees, Lincoln Towncar limoes, Chrysler 300s, ice floes, etc and sticks out enough to protect the fenders unlike the junque shown here.
Hi guys,
ID:	36291   Click image for larger version
Old February 28th, 2011, 09:43 PM
Broncoduecer
peter
D90
Yea, rockware. I was looking at them when I had a disco actually. I couldn't remember who they were. I did like their stuff. Something to think about.
Pete
Old February 28th, 2011, 10:19 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
+2 on the Rockware. There are a bunch of pictures of them on the site and with searching but if you need any let me know and I'll snap a few of mine.
Old March 1st, 2011, 04:23 PM
Birdman's Avatar
Birdman
Chris Bird
1995 D90 ST #2046
Yes on the sliders. I think the snorkle is Mantec; I just switched the cap from a mushroom to Safari to be different.
Pete
Old March 6th, 2011, 12:59 PM
Broncoduecer
peter
D90
Will the 95 front directional fit where the 94 running light is? From the pics on the net it looks like it's a little offset, but that may be just because it's larger. If i really wanted to go with the 95 lights, are there any surprises using the surrounds from a 95? Like headlights being off by 1/4 inch and not fitting or some other weird issue? Or can you just use them with the 94 surround...?
Thanks guys.
Looks like rockwares bumper just went up by a 100 bucks, that or it was an old link. And i see they have a rear tire carrier.
bumper
Feeler- Equipe Competition winch bumper jaygoss Wanted 6 October 17th, 2010 02:32 AM
equipe bumper huck1974 Defender Technical Discussions 38 April 27th, 2010 12:31 AM
bumper mounted fogs on Equipe comp bumper jaygoss Defender Technical Discussions 11 April 17th, 2010 12:37 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
