Equip rear diff guard install - Defender Source
Old May 24th, 2013, 11:44 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
What am I doing wrong? The top bracket is quite a bit too short. Do I have the wrong part? Was sold to me 2nd hand to fit RRC/D1/D90.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old May 24th, 2013, 11:52 AM
The Dro
Dro
1988 Ninety
It looks like it's not sitting right.
Clean that diff out and see if it will slide in further.
Also, might need to remove the paint from the "ring".
I may have painted it too much and now it doesn't fit.
Old May 24th, 2013, 12:21 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
that looks like more than a paint problem!
Old May 24th, 2013, 12:45 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
its a long weekend...take it to Dro's.
Old May 24th, 2013, 12:47 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Loic, I installed the same. Install the ring over the top of the diff first and loosely secure the hardware. Then use a floor jack to press up the pinion guard side to help slide the bottom of the ring over the diff with a little massaging (i.e., a no bounce, large flat chisel, a shot of PB, etc.) as required.
Old May 24th, 2013, 01:03 PM
I think some diffs have a thicker mounting flange. I had to cut and weld on the top part of my Southdown rear diff guard. (big steel diaper type)
ID:	73033   Click image for larger version
Old May 24th, 2013, 01:40 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Equipe diff guards came with two top brackets, no matter what, one of them never fit. I wonder which one you have?
Old May 26th, 2013, 07:40 PM
MonLand
Loic Fabro
So... Since I have under the gun I did not go the cleaning route. I think cleaning might help since after some hammering, strapping, etc it looks almost there. I'm unclear what that top bracket is supposed to do, so I went ahead and left everything hanging. Since I ended up not sliding on anythingl
I also talked to Charles and told me to stop being a sissy since classic LRs are not precision item and most of the time nothing quite fit without a BFH.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old May 27th, 2013, 01:48 AM
Nine-Zero's Avatar
Nine-Zero
Stephen Beres
Defender 90, 1994 NAS
I have the same guards and I went with the floor jack method. Get the top plate fitted, then use a floor jack to push the very front of the drive shaft protector up and hammer and pry until the bottom bolts line up.
Equipe 4x4 wraparound REAR diff guard crown14 For Sale - Parts 13 January 21st, 2011 12:03 PM
110 rear diff clunk D90user Defender Technical Discussions 14 November 19th, 2005 01:49 AM
need front/rear diff for 1994 D90 rover_rich_d90 Wanted 4 March 14th, 2005 09:05 PM
Wanted: OEM rear Diff gaurd Northface Wanted 3 February 19th, 2005 08:21 PM
Barnett Childress chrisvonc Defender Owners 0 February 29th, 2004 12:47 PM
