Engine Year of Manufacture by Engine Serial Number - Defender Source
Old February 21st, 2017, 11:03 AM
Sauber's Avatar
Sauber
Ben
1985/110
Do any of you know of a way to determine a year or range of years in which a particular engine was built?
I have an `85 110 with a later 200TDI swap and I'd like to know when the engine was built. I've encountered no shortage of help in finding information to decode my truck's VIN, but looking up the year of manufacture for a particular engine is turning-out to be more difficult than I expected.
Glencoyne Engineering has been the most helpful source I've found to-date, but it only helped me determine the engine I now have was originally installed in a Defender (11L prefix).
Old April 3rd, 2017, 09:33 PM
Vedrover
Alex
1988 Land Rover 110
I went through the same on mine. There actually are YoM stamps on the engine block, which are usually hard to see because they are covered by crud and obstructed by other engine bay components. Mine had them on the LH side and I have only been able to see them when I pulled the engine out and pressure-washed it. Other parts can usually give you an idea like oil cooling lines, for example, have YoM stamped on their metal rings (although these could have been replaced and, therefore, be "younger" than the engine). Other than that I couldn't find any way the "decode" the engine serial number to tell the YoM.
ac, engine
Matching Engine Number? 300td Gibson Defender Technical Discussions 2 July 15th, 2016 08:26 AM
Help decoding exmod 3.5 engine number akrockhound Defender Technical Discussions 12 December 3rd, 2014 02:57 PM
Engine number 300tdi cjbenway Defender Technical Discussions 3 April 11th, 2013 04:44 PM
Where is the engine number on a 3.9 V8? JimC Defender Technical Discussions 2 October 25th, 2007 08:29 AM
telling the build year by the engine serial number cdb Defender Technical Discussions 2 August 16th, 2006 08:45 AM
