Engine wont turn over - Defender Source
Old May 23rd, 2015, 12:14 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Filled up at a gas station and got back into my truck and i couldn't get my transmission out of park. This happened to me before when my brake switch failed and the replacement wasn't adjusted properly so I shorted the brake switch wires together and voila i was able to put it into drive.
Got home and started to try to adjust the switch (what a bitch it is to get to) and kept trying the transmission , shutting the engine off between attempts. Finally I tried to turn it back on and it would turn over... Battery is fully charged... Everything else comes on and works... Just the starter is not engaging...
Any thoughts?
Old May 23rd, 2015, 03:30 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I wasn't even touching the shifter except to shift to drive... The break switch is under the hood... I've been meaning to disable that solenoid for a while... Just a bitch to get to...
Old May 23rd, 2015, 11:40 AM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Have you checked the fuses or grounds?
Old May 23rd, 2015, 06:46 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Mark,
Maybe something in the Vancouver air?
SWAMBO (Sy wat altyd met besem opstyg) just called me. She's up the mountian on a Roverlanders run with a failed clutch!
Old May 23rd, 2015, 06:50 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I was all set to go on that run and this happened the day before. No way I would go without my vehicle 100%. My kids cried when I told them we couldn't go.
Help! Cant get the key to turn over hotroddef90 Defender Technical Discussions 10 October 27th, 2012 04:51 PM
Won't turn over gtg067i Defender Technical Discussions 6 September 27th, 2009 09:18 PM
Just did an engine swap and now wont run... RyanB16 Defender Technical Discussions 16 March 4th, 2009 11:29 AM
Wont run at temp Neo Defender Technical Discussions 12 February 24th, 2006 06:54 PM
new bfg wont balance mattdh Wanted 7 October 27th, 2003 12:25 PM
