Engine Wiring Harness - Defender Source
Old September 24th, 2010, 02:19 PM
61rover's Avatar
61rover
John Crouse
How difficult is it to change out the engine wire harness. Mine seems really brittle in several places and they aren't that expensive. Just wondering how hard they are to install.
Old September 24th, 2010, 09:55 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
I had Pendy pull the old harness and put in a Painless harness when he transplanted the HS2.8.
If you ask him I think he will tell you it was not easy!! Take into account there are virtually NO electronics on the 2.8 compared to the 3.9 or others. He actually seems to have gotten rid of a LOT of wiring.
Here is a pic of the painless set up.
Old September 24th, 2010, 11:10 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
I was thinking about the engine harness on mine for some reason and it's pretty simple. I'm not sure about the V8 one.
Old September 25th, 2010, 04:39 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Engine harness is pretty easy (the bulkhead one, with the dash, is fiddly)
On the engine, i'd lay the new harness on top of the engine first, make sure all the leads are the correct length and have the correct plugs/terminals on the end (to match what's already on there)... you don't want to pull the existing loom off then be left in the lurch with a dead truck.
If you're not too electrical savvy, then i'd take some pictures of the cable routing and what goes where, so you can refer to if when you refit the new one.
And just be careful when you pull the wires through any gaps, that there are no bits getting caught on some sharp corner and stripping back the plastic insulation.
engine, wiring
D90 Engine Wiring Harness for sale Snatcher For Sale - Parts 4 April 2nd, 2008 03:53 PM
cheapest place to get an engine wiring harness defender1844 Defender Technical Discussions 10 January 12th, 2008 12:12 AM
90 main wiring harness & TDI engine mounts TDI Guy For Sale - Parts 5 December 13th, 2004 01:45 PM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
