Engine Water Temp Gauge 80% Dead - Defender Source
Old December 27th, 2014, 11:34 PM
RBBailey
RBBailey
1965 IIa
Won't work about 80% of the time.
Will show temp, then drop to nothing, on and off.
Which probe at the front of the block is the right one to look at? There are three that look like temp gauge probes.
Might it be the gauge itself?
I checked wires for bad connections, but only got so far in the few minutes of light I had.
Any ideas on what and where to look?
Old December 27th, 2014, 11:46 PM
Absolutely sounds like a bad ground. I would start there.
Old December 27th, 2014, 11:54 PM
RBBailey
RBBailey
1965 IIa
On the bulkhead someplace?
Old December 27th, 2014, 11:56 PM
My NAS temp gauge was doing the exact same thing. Checked grounds, sender wire, etc. Problem still persisted. Swapped to VDO gauge & sender, problem went away...so presumably was either the gauge itself or sender unit.
Old December 28th, 2014, 12:05 AM
If it is a '94 or '95, it looks like this.
If it is a '97, it looks like this.
Old December 28th, 2014, 02:20 AM
RBBailey
RBBailey
1965 IIa
It's a 1988 LHD 3.5 V8
I'll look tomorrow in the light, but there are several. And I think they are on the same wiring harness.
It is more like the '94 style.
Old December 28th, 2014, 05:00 AM
Pull the wire off the sender and ground it directly to the block. If the needle doesn't move it's the gauge.
Old December 28th, 2014, 08:07 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
It's this one…. but I'd recommend installing a VDO gauge & sender. I wanted to keep the original gauge so I installed the sender above the original one in the intake manifold.
ID:	109571   Click image for larger version
Old March 24th, 2015, 10:51 AM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
I had a little of the same issue...
I pulled the wire and grounded it to the block and needle made a nice smooth move to peg. I put the wire wheel on my battery powered Dremel (best thing to own for the 90 imho) and cleaned off both the plug and the probe. Now my needle sits just left of center when truck is warmed up which is where I hear it's supposed to be....
Attributed to Shayne...
Old March 25th, 2015, 08:55 PM
RBBailey
RBBailey
1965 IIa
Well. I confirmed that the gauge works when the wire is grounded to the block. I also cleaned the contacts. No go.
Not a big deal since the engine and all is for sale. Basically it just means I don't have a true excuse to buy my first VDO gauge when I do the Tdi swap.
Project:
1965 IIa SWB
Old March 25th, 2015, 08:57 PM
You need a new sending unit.
Old March 26th, 2015, 12:20 PM
RBBailey
RBBailey
1965 IIa
Yeah. But I'm not even going to worry about it now. When I started the thread I didn't have the Tdi yet.
Project:
1965 IIa SWB
engine, water
Water Temp Gauge javelinadave For Sale - Parts 2 September 7th, 2014 04:33 PM
Water temp gauge bcourtney Series Technical Discussions 3 May 27th, 2012 08:10 AM
Water pump dead? durangorover Defender Technical Discussions 7 April 30th, 2009 10:50 AM
oil pres + water temp gauge??? revtor Defender Technical Discussions 1 July 10th, 2007 09:35 PM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
