Engine turns over when shutting off - Defender Source
Old June 24th, 2012, 09:54 AM
usadventureracing's Avatar
usadventureracing
Brett
110
Every so often (2x now) when turning off my truck the engine will turn over just after I turn her off. Any suggestions on what could be the problem? Thanks
1983 ROW D110
1970 Series III (Parting out)
Old June 24th, 2012, 10:19 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
As in, you turn the key to the off position ready to pull it out, and the engine will spin over?
Sounds like the ignition switch to me.
Old June 24th, 2012, 10:21 AM
usadventureracing
Brett
110
Yes that is what happens. Is there a fix besides new ignition? Is it just sticking, I was told by someone to spray a little WD into it.
1983 ROW D110
Old June 24th, 2012, 10:40 AM
michael67's Avatar
michael67
Michael White
110 Tdi
If you're going to spray it, use some lock lube spray. Ace hardware carries it last I checked.
Old June 24th, 2012, 10:49 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Don't think that'll work, as the "switch" part of the lock is just screwed onto the back of the actual lock barrel piece with a couple of small screws... so the "switch" bit doesn't get any of the barrel/key parts in it.
It sounds like one of the terminals on the switch has either come loose, or is just touching (or nearly touching) and making the engine turn over.
engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Engine turns over but won't start bd90 Defender Technical Discussions 9 August 8th, 2008 12:22 PM
