engine/transmission mounts - Defender Source
Old January 8th, 2010, 10:13 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Does any one know the difference between ANR2805 and NTC5890? They seem identical in pictures except the NTC5890 seems to come with bolts. Is that the only difference?
Old January 8th, 2010, 11:00 AM
Have you seen the QT services engine mounts? I dont remember part numbers but when I did the LT230 in my RRC I replaced all the engine/t-case mounts and the best I can remember they were the same part.
Old January 8th, 2010, 12:07 PM
cboy
eric choy
SIII 88"
The ANR2805 has M12 studs while NTC5890 has M10
http://www.lrseries.com/shop/product/listing/2913/3009/3/ANR2805-MOUNTING-RUBBER.html
http://www.lrseries.com/shop/product...BBER-M10-.html
Old January 8th, 2010, 12:30 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
NTC5890 fit 94/95 engines. ANR2805 fit 97 engines
The frame & engine mounts holes on the 94/95s are smaller.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 9th, 2010, 11:27 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Thanks! Good to know the size difference--I appreciate it.
engine, mount, transmission
ARB Hi-Lift Mounts Dfndr90 Defender Technical Discussions 4 September 1st, 2005 03:43 PM
Installing engine mounts Doug Defender Technical Discussions 4 February 23rd, 2005 06:49 PM
weld on motor mounts pendy For Sale - Parts 3 September 8th, 2004 03:10 AM
Expeditionware shock mounts dave_lucas For Sale - Parts 4 September 1st, 2004 04:20 PM
Scorpion racing Rear upper shock mounts for stock trucks! dmarchand For Sale - Parts 2 July 8th, 2004 12:57 PM
