Engine Temp - Normal range - Defender Source
Old June 10th, 2004, 10:49 AM
mgrgpg
Mark
1989 D110
What would be the normal running engine temperature for a 94?
Mark
Old June 10th, 2004, 11:31 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Mark,
My gauge seems to always be 1/2- 3/4 of the way.
Old June 10th, 2004, 02:29 PM
mgrgpg
Mark
1989 D110
Thanks...my stock one was the same, now I have a VDO with degree F markings, and was wondering what the actual number was.
Mark
Old June 10th, 2004, 05:05 PM
scoloco's Avatar
scoloco
'94 D90 ST
'94 3.9 with 78k on the clock. Stock guage is in the middle after it warms up and generally stays right there. A mechanic read the temp with one of those fancy gizmos at the radiator. ~170' at the hot end and a lot cooler at the other end, if I recall correctly. So I figure 160-180'F for mine.
Old June 10th, 2004, 05:59 PM
Depending on the T-stat thats in there it should be either 180F or 160F, They only use the 160F if the engine has overheating problems or it's used in very hot climates.
Old June 10th, 2004, 08:47 PM
mgrgpg
Mark
1989 D110
Thanks....Mark
engine
What's normal water temp range? btate Defender Technical Discussions 8 May 29th, 2006 12:17 AM
Engine Temp issues sflash868 Defender Technical Discussions 11 May 25th, 2005 04:51 PM
95 D90 temp sender range naeirie Defender Technical Discussions 2 April 27th, 2005 12:16 PM
