Engine Temp issues - Defender Source
Old February 25th, 2005, 12:48 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Engine Temp issues
I'm sure this has been brought up before, but i can't find a thread on it, so if this is a repeat i'm sorry. My defender keeps over heating... so says the gauge, but I have changed the radiator, water pump, thermostat and all other related parts, the only thing i haven't changed i the physical gauge. I drove it around Moab in the summer and the gauge hung out around the red but never got above it. If i picked up speed the gauge would drop down in less than a minute. It seemed whenever wind hit it, it went down to normal. It does this on the highway too. While off-road it occasioanlly randomly stalled and sometimes had a hard time restarting. I don't think the gauge is accurate, but what should i look at to remedy the problem. The stalling is also a bitch when you are driving up the launching pad in moab and your engine quits.
Old February 25th, 2005, 01:05 PM
This has been covered a lot. If wind or speed has an effect check your clutch fan, should be hard to turn it when the engine is hot and off. But your gauge may never go above red if it goes into red you should have shut it off and let it cool down.
Old February 25th, 2005, 03:38 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Factory gauge many have found to be unreliable. There are a couple of recent threads covering install of mechanical gauges. Mine is a AutoMeter, hung under the dashboard, with the temp sensing bulb plugged into the hot side of the radiator. I had a rad shop put the fitting in for me. Very accurate degree read outs.
Doug W.
Old May 13th, 2005, 09:39 PM
naeirie's Avatar
naeirie
Nilo Enerio
95 D90 ST #2571
I just replaced my stock water temp gauge with a mechanical gauge(AutoMeter part# ATM 2606). I purchased from egauges.com (http://egauges.com/vdo_mult.asp?Type...Z-Series&Cart=). I used an adapter from SunPro so that the probe goes directly where the electronic temp sender is. (http://sunpro.com/product_detail.php...b684f92fa7291e) It's so much nicer (piece of mind) to read real temperature reading. I will post pics if interested.
Nilo
Old May 13th, 2005, 10:37 PM
mattdh's Avatar
mattdh
Matt Hurst
nilo can you post pics-do you have one of the sender and it installed
Old May 13th, 2005, 11:31 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
as mike said, it really sounds like a fan clutch (sometimes known as a viscous fan clutch, viscous fan, thermal fan clutch, etc.) They go out quite often on the defenders. I'm putting an electric fan unit in our 94 and many on here have done that with very good results.
Old May 14th, 2005, 01:39 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Yeah, from the desciption it's definitely a fan-clutch issue.
In fact, once again, if anybody can tell me the threads on the existing fan/water pump, I want to see if the flex-a-lite adapter to hook on a flex-fan will work for us. There are a bunch of aftermarket fan-clutches out there, but I need to know the threads.
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 14th, 2005, 02:01 AM
naeirie's Avatar
naeirie
Nilo Enerio
95 D90 ST #2571
pics
Hi Matt,
Here are the pictures.
Nilo
ID:	3166   Click image for larger version
ID:	3168   Click image for larger version
Old May 25th, 2005, 02:58 PM
jabber
m j
110
Any reason/benefit of mechanical versus electrical?
Old May 25th, 2005, 04:40 PM
Hans's Avatar
Hans
Hans Haase
In theory, a mechanical fan can flow more air (When everything is working), but sucks down horsepower and can't be shut off for water crossings nor can it be kept on when the engine is stopped.
Electrical fans (in theory) flow less, but are more versatile and don't take up as much engine power.
I've been trying to source some different mechanical options, but have come up dry so far. A few leads to follow, without the cash to take the plunge.
-Hans
My oil line fix
Old May 25th, 2005, 04:44 PM
jabber
m j
110
ooopppsss... I meant gauges... Mechanical versus electrical gauges. Sorry.
Old May 25th, 2005, 04:51 PM
naeirie's Avatar
naeirie
Nilo Enerio
95 D90 ST #2571
major reason I switched to a mechanical gauge is to get an accurate reading as far as my temp engine goes. I found the electric gauge/sender to be very unreliable.
engine
Experiencing wierd electrical problems, engine power issues? madcowdungbeetle Defender Technical Discussions 0 May 26th, 2008 10:14 PM
Lifter / engine tapping... oil pressure issues.. revtor Defender Technical Discussions 10 July 12th, 2007 11:04 PM
Engine Temp - Normal range mgrgpg Defender Technical Discussions 5 June 10th, 2004 08:47 PM
