Engine Swap Suggestions - Whats Next 2.8L TGV is getting scarce - Page 2 - Defender Source
Old June 4th, 2013, 11:47 AM
Viggen's Avatar
Viggen
Jarrod
none
Wasnt the 4BD1T an option in the 110 in Aus?
Old June 4th, 2013, 01:47 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
Do you think the 2014 Jeep 3.0 Diesel with 8 sp. transmission will be option down the road?
Old June 4th, 2013, 01:57 PM
Viggen's Avatar
Viggen
Jarrod
none
That is a LONG transmission. Then slap on a thick transfer case like the 230 and you probably have a space issue.
Old June 4th, 2013, 01:59 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Damn. Out of curiousity, how much is a brand-new crate OM617
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old June 4th, 2013, 02:03 PM
brand new? do you mean rebuilt?
Old June 4th, 2013, 02:05 PM
chris snell
Chris Snell
87 Ex-MOD 110
Robert suggested that new ones were available.
2013 LR4
Old June 4th, 2013, 02:56 PM
Originally Posted by bsjbrown View Post
I do not intend to keep my 2.5L Turbo D in my Landy. Frankly it just is way too underpowered.
200TDI good idea? but not much of a change.
300TDI - excellent choice but I want to swap after the first of the year and I believe the 300TDI is not going to be 21 years old yet, until 2015
Throwing this out there for technical discussion.
The differences between a 200 and 300 are minimal to the point that they are exactly the same displacement and one puts out 2hp more than the other. 2hp which is easily overcome/regained with correct injection timing and tuning (factory settings are somewhat retarded from optimal). The 200 tdi would be the obvious choice for your rig. You are seemingly misinformed on it vs your 2.5 td if you think the 300 would be an "excellent choice".
I have a defender 200tdi complete setup that will be available in the next 30 days or so if that is of interest.
That said only the Benz engine or baby Cummins or detroit iron are ever going to be legal transplants if you are worried about legality.
------ Follow up post added June 4th, 2013 03:03 PM ------
http://www.mercedesengines.net/products.asp?cat=40
Old June 4th, 2013, 04:55 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Yeah, I think 200 TDI makes most sense since it's almost a drop in proposition. That would be easy peasy.
For a custom app. I think a VW TDI would be cool. Maybe when my jetta dies I will use the engine for a Rover. Going on 400K miles.
JL
Old June 4th, 2013, 06:11 PM
Cube II's Avatar
Cube II
Michele
1997 D90
When you'll do, let me know
Jim (Hall) had and still has? one in his Series...
I love the idea, and they should be unexpensive around here...
------ Follow up post added June 5th, 2013 12:13 AM ------
Originally Posted by defeyago View Post
One of my Dīs has stock 2.5 300tdi but with 2.8īs IP,(...) and it does make a huge difference.
Hola!
Tell more about the pump?
What's the trick?
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old June 4th, 2013, 06:19 PM
BlackField's Avatar
BlackField
Oscar
D110
Didn't South African market Defenders use BMW engines? An inline 6 would be cool. I wouldn't mind seeing a BMW Diesel or even an XJR supercharged inline 6 under the hood of my truck one day.
Old June 4th, 2013, 06:20 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
But wouldn't the Isuzu 4bd1t be legal since it's in the NPR trucks here in the states?
Old June 4th, 2013, 06:24 PM
I think it has to be out of the same year or newer and it has to be the same GVWR or lower but as a rover V8 guy I never dug in.
Old June 4th, 2013, 06:34 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Having driven a D90 with a GM Gen III 5.3 vortec V8 a month or so ago, I can tell you it's extremely tempting.
Are you set on Diesel?
Edit: wrong engine....
Old June 4th, 2013, 08:58 PM
Viggen's Avatar
Viggen
Jarrod
none
Doesnt matter. The motors are medium duty diesels and are not legal for swaps into a light duty truck. Like I said earlier, I think that the 4BD1T was used in 110s in Australia so there might even be a bellhousing to use a Rover transmission. You could probably get away with that swap since the feds seem not to care all that much about it (there is an entire website devoted to it after all).
A 5.3/ 4L80E combination would be killer. If you can retain all the goodies (completely possible), you might even be able to keep the cylinder deactivation and pick up some mpg.
Old June 4th, 2013, 10:27 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Originally Posted by Viggen View Post
The 4BD1T was used in 110s in Australia so there is a bellhousing to use a Rover LT95.
Fixed it for you. There is no question about it's existence. They were factory fit for the AUS market.
1970 SIIA 88, Sold
Old June 4th, 2013, 10:45 PM
Yes but they are not available except used.
Old June 4th, 2013, 11:20 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Bellhousings for a 4bd1t?
1970 SIIA 88, Sold
Old June 5th, 2013, 11:34 AM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
Pray tell more. I have decided that when my 300 tdi gives up the ghost, a GM V8 will go in.
Old June 5th, 2013, 11:56 AM
Correct. The parts needed to mate an Isuzu engine to a Land Rover gearbox were custom made by Land Rover Australia and the only ones that exist are on existing vehicles.
Old June 5th, 2013, 12:25 PM
Viggen's Avatar
Viggen
Jarrod
none
Thanks. So, LT95 and then an overdrive and you would have a factory(ish) setup.
engine
Swap 200 Tdi woth a BMW or Mercedes engine lakis Defender Technical Discussions 20 December 13th, 2015 11:37 AM
Engine swap project with a twist. Recommendations? HeloBubba Defender Technical Discussions 0 February 11th, 2011 10:46 PM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
