Engine Suddenly Stops - Defender Source
Old September 12th, 2011, 09:04 AM
NigelD90
Jon Haskell
1997 NAS D90
My NAS 1997 4.0Liter D90 with 298,000 miles, exhibited classic faulty Crank Position Sensor symptoms...engine suddenly stopping after six miles or so, but could be restarted after 10- 15 seconds. No sputtering...a quick stop.
I replaced the sensor and repaired frayed wire insulation at the connector.
It ran perfect for three days then the problem surfaced again. (The ambient temperature was cooler those days...not sure of relevancy) The problem remains sporadic and can happen regardless of terrain or speed. The last event was at idle speed others at 40-50mph.
So...what are the groups thoughts on some other things that I should look into?
thanks much....Jon
Old September 12th, 2011, 10:15 AM
djrover's Avatar
djrover
Dave Johnson
'91 RRC
I am sure you checked the wiring to the fuel pump and the ground. Common place to corrode, break, etc...Or the pump itself.
_________________________
Dave J.
'91 RR Classic
'01 RR 4.6 HSE - Gone!
'00 Disco 2 - Gone!
'95 Disco 5-Spd - Gone!
'92 RR County SWB - Gone!
'63 2A SWB - Gone!
Old September 12th, 2011, 10:53 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Check the wiring on the bottom of your ignition coil. Those spade connectors can sometimes work themselves loose, which will produce those symptoms.
Old September 12th, 2011, 04:44 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I had something similar and it turned out to be a faulty ignition switch. I would just die on the freeway, then I could not restart and then, out of nowhere, it would restart fine.
engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Engine Stalls Suddenly When Driving Ragland Defender Technical Discussions 15 February 4th, 2006 12:30 PM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
