Engine Stutter - Defender Source
Old December 27th, 2004, 09:27 PM
caschumann's Avatar
caschumann
Creg Schumann
1997 D90 SW
Engine Stutter
Hello:
I've had my '97 D-90 SW for a few months now. However, in the last days, there seems to have developed a stutter in the engine when traveling over 45 MPH. It will run smoothly for about 5-15 seconds, and then stutter. Just this evening, the Check Engine light went on during the drive home.
I'm thinking this can't be good. Any hints before I call the LR Shop tomorrow?
Thanks!
Old December 27th, 2004, 10:16 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
02 D2, 13 E350 AMG, 11 Ford F350
If the CEL is on. I would first take the Rover to AutoZone to pull the codes (there will be no charge for this). Once you have them take them and plug them into this site: http://www.iequus.com/obd_def.asp
Sputtering could be: the fuel filter has gone bad, plugs or wires, misfire on a cylinder, fuel pump dying. Most of the aforementioned are fairly easy to change out if you have rudimentary mechanic skills and a manual. Good Luck. If it were me I would avoid the dealer like the plague!
I bought the diamonds myself so I would not have to say thank you to anyone.
Old December 28th, 2004, 10:55 AM
mspell
Michael Spellman
Not sure on a 97, but my 95 did the exact same thing & it was an overheating ECM. I relocated off of the distributor onto the pass fender.
engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Yet another engine fire chrisvonc Misc. Chit-Chat 80 August 30th, 2005 02:22 PM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
