Engine Stumble/exhaust leak when cold? - Defender Source
Old December 21st, 2015, 01:13 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
1995 NAS D-90, 4.6. Has this strange issue that is primarily tied to the ambient air temperature/ engine temp. When first starting (so totally cold) it will fire up fine, idle fine but when you rev it, it stumbles like it's down a cylinder and sounds like it has a bad exhaust leak. Once it warms up, revs fine, exhaust sounds fine, no stumble, idle is still fine, pulls strong.
I did some searching and there are numerous threads about engine stumbles but those are always associated with a rough idle or intermittent dying. I have none of that.
Recent changes: new temp sender, new ICV, and the dealer recently adjusted the base idle (despite be telling them it needs a new ICV and to not touch the idle). I checked the leads, sprayed around for an air leak, checked the usual connections and all seems fine.
I thought my best chance is a timing issue but isn't it backwards? Usually you set the timing and issue would show up while hot if the advance wasn't working? If the advance was set too far after TDC could it stumble while cold despite everything else working properly? I believe I set it to 12 after TDC.
Appreciate suggestions. Thanks
Old December 23rd, 2015, 02:45 PM
Departing90
Sasha
95 D90
Is your engine a "4.6" with a distributor? Your symptoms sound like typical mass air flow sensor issues. Look for leaks, remove and clean with carb cleaner spray "watch u tube videos" and reassemble. If no luch find a known good maf sensor to test. Its not your timing unless your revving to redline and symptoms appear. Timing issues generally show tye same symptoms at all heat ranges and rpms.
------ Follow up post added December 23rd, 2015 02:52 PM ------
If you have a distributor also check tye vaccume advance "its a disc / dome shape gismo" on the side of tye distributor by taking off tye hose and checking suction by placing tye tip of your finger on the outlet. If you dont feel suction tye vaccume advance is bad. Check for leaks in tye hose between the vaccume advance and intake.
Take off tye distributor cap and check play in the rotor. If you have play tye advance mechanism underneath tye rotor cover is bad.
Old December 23rd, 2015, 03:08 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Also, what distributor are you running? Does it have a ballast resister such as many of the Mallorys use? If so, you may want to check that out. Mine had some stumbling issues once and I traced it back to that. To me, though, it still sounds like an IAC issue and/or vacuum leak. I know that you said it was replaced---but it still sounds like that particularly on the cold start where that is in use.
Old December 23rd, 2015, 03:12 PM
Does it happen all the time, or only when it rains?
Old December 24th, 2015, 01:13 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I took a second after reading the responses and I think I might have found the culprit. The Vaccum advance is dead. Sucked on the hose and it pulls air so that's not working. It's not the line so the diaphragm must be shot. Curious why that would be the issue though. Doesn't the advance mainly deal with the higher rpms?
Old December 24th, 2015, 01:32 PM
the rover shop
shayne young
No.. Vacuum advance deals with throttle, mechanical deals with engine speed..
Old December 24th, 2015, 06:21 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
So theoretically that could be the problem since the stumble only happens when throttle is applied?
engine, exhaust
Intermittent stumble Coug D90 Defender Technical Discussions 7 May 26th, 2015 11:17 PM
Inconsistent stumble and stall aosias Defender Technical Discussions 13 March 31st, 2014 01:06 PM
3.9 stumble stall code 44 rover4x4 Defender Technical Discussions 5 April 4th, 2009 02:39 PM
Excessive Cold Weather Exhaust boshea Defender Technical Discussions 3 January 9th, 2005 02:44 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
