Engine Stalls Suddenly When Driving - Defender Source
Old August 9th, 2005, 09:57 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
After searching through older posts, I didn't see one quite like this.
I'm driving down the road, and within about 5 to 10 minutes of starting, the engine loses all power. No shifting, no dying at idle, just cruising anywhere about 30 to 60 and without warning the engine quits. When I try to restart, it will faintly fire then die. It takes waiting at least a minute or two (which seems like eternity in the middle of the road) before it will start and run. Once it restarts, the check engine light clears.
As for the error codes, I did catch an "03" a few times, indicating the ecu if I am correct. Is this what starts to happen when the ecu fails? Any other guesses?
"Uhh...I think they all leak like that."
Old August 9th, 2005, 10:16 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
maybe a fuel pump? It's an option worth investigating.
Old August 9th, 2005, 10:45 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Might be the ignition control module.
Old August 9th, 2005, 11:03 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I'd 2nd the ignition module. It's located real close to the radiator hose, and I believe there were heat induced issues with it in that location. I know somebody makes a relocation kit to move the module away from the engine to cure the problem.
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 10th, 2005, 08:59 AM
Abrooks's Avatar
Abrooks
Tony Brooks
STC 1856. I put a heat sink on the back of the new bracket as well just to ensure it won't cook again.
Old August 10th, 2005, 09:08 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I recently purchased a Mallory Unilite distributor--the unilite module takes place of the ignition control module and you will be done with it forever. Replacement unilite modules called the e-spark are about $37 from Summit. The distributor runs great and the whole shebang costs less than a relocate kit/ignition module. FYI.
Old August 10th, 2005, 10:25 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Let's see some pictures and a write-up!
Old August 10th, 2005, 02:16 PM
NICE CHRIS! Sounds like a must do mod!
Old August 10th, 2005, 02:26 PM
tmore
Tom More
1995 D90
where did you get the distributor from and do you have a part#?
Ttom
Old August 10th, 2005, 05:30 PM
COSteve
Steven Reed
93 Defender 110 - #107
Hey Anthony, what kind of Heat sink did you stick on the back of the relocate unti?
COSteve
Old August 10th, 2005, 05:38 PM
Hans's Avatar
Hans
Hans Haase
You can also do 215 buick distributors from either MSD or one of the new Accell Dual-Sync distributors as well, though some modifications are needed to put on the later type Rover drive gears.
-Hans
My oil line fix
Old August 11th, 2005, 08:34 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Picked one up from the computer aisle at Radio shack, reconfigured where the brackets were on the plate, trimmed the screws that hold the module on so that they were flush with the back of the plate and used some sort of heat-sink adhesive to adhere it. I'm assuming it works since it hasn't blown up.
Old August 11th, 2005, 11:23 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Thanks for the responses everyone. The ignition module sounds like a good call, and one I will look after this weekend. There are so many threads on stalling, I accidently overlooked it. Perhaps we need one entire category, maybe a sub-group under the "Looking for help?", dedicated solely to engine stalling. Next to "Overheating or Running Hot?", that is.
Old August 11th, 2005, 11:44 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I will dig out all the distributor info and do a write up this weekend.
Old August 11th, 2005, 11:46 PM
COSteve
Steven Reed
Anthony, thanks for the description, I can see in my mind exactly how you did it. Will try it !
Old February 4th, 2006, 12:30 PM
Antonios
Antonios Hadjigeorgalis
No more
Did you ever get a chance to post this info?
How do you diagnose that the ignition module is the problem?
Miami, FL
engine, vin
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
