Engine Squeak - Defender Source
Old January 24th, 2011, 07:40 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Engine Squeak
My 97 is making a squeaking noise right at the front of the engine behind the grill. Seems much worse at cold start ups and gets better when hot. I can't seem to locate it with a stetho. I hit the belt with some soap to see if it changed and it did nothing. I have an extra belt so I might put it on.
Anyone think of something else I should look at? It runs fine.
Rich
Old January 24th, 2011, 09:08 AM
Rich
tensioner or idler pulley bearings going out most likely.
Old January 24th, 2011, 10:01 AM
Naplm00
Matthew
Or your power steering fluid is contaminated and is thickening win the cold weather, making the PS pump pulls stiff to turn and the belt is squealing over it.
I just remedied this in my girlfriends 91 Landcrusier
Old January 24th, 2011, 01:24 PM
Campbell's Avatar
Campbell
Rich Campbell
Thanks for the responses.
Old January 24th, 2011, 05:50 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Sometimes even if the belts look good with no cracks they can still be "Glazed" and cause chirping...especially the v-belt rigs. If you don't know when they were done than you might want to change'm before you go replacing more expensive things.
Old January 24th, 2011, 07:29 PM
grab the water pump pulley, ps pulley idler, alternator etc and check for play with the engine off of course.
Old January 25th, 2011, 10:12 AM
Campbell's Avatar
Campbell
Rich Campbell
Looks like it might be the water pump on the way out.
Old January 25th, 2011, 01:11 PM
Buy genuine and get the genuine gasket. Change it asap before it blows up.
Ron
Old January 25th, 2011, 01:32 PM
Campbell's Avatar
Campbell
Rich Campbell
Ron
Well it turns out to be the alternator.
------ Follow up post added January 25th, 2011 06:33 PM ------
Thought for sure it was the water pump.....I think the alternator was original.....140k
Old January 25th, 2011, 03:03 PM
Call roverguy and get a magnito merelli one from a P38a and swap the pully to make it fit your truck.
Ron
engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
4.0 used, complete engine dmarchand For Sale - Parts 0 September 28th, 2004 03:12 PM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
