Engine running rough temporarily - Defender Source
Old May 11th, 2009, 09:30 AM
What are candidates for the engine running like crap for a few minutes and then "self healing"? I was driving a heavily rutted road at speed yesterday right before it happened, but was on tarmac when it occured. I could smell the exhaust, then when came to a stop the engine was missing and felt like it wanted to stall. A minute or so later it was fine.
I'm guessing something is vibrating loose, but what?
thanks,
charles
(oh, this is on my '94 D90)
Old May 11th, 2009, 09:50 AM
coil wire. This happened on a friends LWB after it was launched over some rail road tracks
Old May 12th, 2009, 03:35 PM
bitz's Avatar
bitz
Jon
NAS D90, 85 D110 CSW, 66 Dormobile
Check the O2 sensors as well. If they come unhooked it will make your truck run like a vw bug.
Old May 12th, 2009, 03:50 PM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
Interesting. My defender has been running just like a vw bug for a while. Where is the o2 sensor?
Old May 12th, 2009, 03:59 PM
LOL. I haven't driven in a vw bug for a long time so you'd have to explain how that feels. Mine is intermittent which makes me think it's not just a loose wire since nothing is tightening the connection again, but when it happens it misfires (on what seems like multiple cylinders) runs rich evident by black smoke (not sure if this is a cuase or symptom) and generally speaking is totally out of power and feels like it will stall.
It just goes away on its own after about a minute.. at least so far. Knock on wood because it happened to me again today
Oh, the O2 sensors are on the exhaust downpipe between the exhaust manifold and the cats (one on each side)
Old May 12th, 2009, 04:26 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Would a plugged catalytic convertor do that? Maybe more so on a rough road.
Old May 12th, 2009, 04:36 PM
Good question although I wouldn't expect that to be intermittent. No codes being thrown either BTW.
Does anyone know how to detect if the cats are causing issues? What is a normal temperature before and after the cats?
I am trying to track down why my truck runs hot when driving slowly in bumper to bumper traffic, slowly on trails, or even long enough at a light in gear (auto box) and have been wondering if the cats could be suspect since I have a rebuilt engine and new beefy radiator. My fan clutch is good afaik, and I think the system is bled properly so running out of ideas.
Old May 13th, 2009, 12:44 PM
clutch fan newspaper test as suggested in another thread? sounds like a fan issue.
Old May 13th, 2009, 01:45 PM
Well, I believe it's good. I did try a piece of cardboard and the fan kept spinning fine. But you tell me - turns maybe a half turn when cold, and maybe a blade when hot (vehicle shut off of course)?
I've been too busy but plan to change it anyway just in case. Got one from Advance for about $60-70
charles
engine
Help.. Tdi Suddenly running really rough TDI Guy Defender Technical Discussions 32 April 25th, 2012 10:37 AM
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Engine will not stay running waveridin1959 Defender Technical Discussions 30 August 1st, 2005 10:09 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
