Engine running rough now a knocking - Defender Source
Old August 28th, 2010, 08:22 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
I did a search and could find an answer. My 90 runs a little rough, seems to have power ok. I unplugged the MAF and such to see if it went away and it didn't. It did set off my check engine light which had the code p0102 but I think that was because I was unplugging things. Since then I have developed knocking during acceleration, not at idle. The rough running seems worse at exactly 1600rmp. I cleaned the PVC and air filter. The spark plugs are fairly new. Going to try wires next. I cleared the code and it hasn't come back.
Things I'm going to try,
Change oil to 5w 30 syn
Change Fuel Filter
Change spark plugs and wires
I want to remove and clean the stepper motor but not sure where it is on my 4.0. Anyone have a picture?
Anything else I should be looking to check? I'm not getting any codes.
Thanks as always
Rich
engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Engine running rough temporarily cgalpin Defender Technical Discussions 8 May 13th, 2009 01:45 PM
Engine will not stay running waveridin1959 Defender Technical Discussions 30 August 1st, 2005 10:09 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
