Engine revving regardless of throttle position - 19J - Defender Source
Old December 18th, 2014, 06:30 PM
IvanKV's Avatar
IvanKV
Ivan
'89 110 County - 200TDi
Exclamation Engine revving regardless of throttle position - 19J
On my way home from the gym tonight my 19J started revving higher and higher even though my throttle was maybe 1/3 on. When I pull off the pedal the engine reacts as it should. But when I push on the accelerator it starts revving higher. This started in 4th gear, now affects all gears. Top speed seems to be 30MPHish, some slight acceleration but NOT nearly related to the sound coming from the engine. When I got home there was a burning smell from the car. No oil coming from the engine, slight oil from the gearbox filler cap, also from where the engine and gearbox, can't say if that was there or not.
19J 2.5 TD / LT77
1989 DEFENDER 110
P.S. Just changed the the master and slave cylinder and bleed the system, maybe one week ago. Ran out of fuel the other day, filled up and it started right up.
PSS - Sorry for miserable grammar.
Old December 18th, 2014, 06:34 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Clutch gone.
Firemanshort
1980 Stage One 109
Sterling, VA
Old December 18th, 2014, 06:57 PM
IvanKV's Avatar
IvanKV
Ivan
well shit
Old December 19th, 2014, 09:02 PM
Greg S
Greg Sutfin
1986 90
Just replaced the cylinders did you? Did you leave some play at the pedal or take it up snug so your clutch never really releases?
Old December 19th, 2014, 10:33 PM
Did you adjust the clutch pedal for freeplay? -Jeff
Check now. You will or have destroyed the clutch.
Old December 19th, 2014, 10:53 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
As others have said pedal free play. If you dont have any the piston in the master cylinder will not let fluid back out into the reservoir and you end up pushing in a little bit more fluid each time you push the clutch. Did you put the spacer on the outside of the pedal tower when you put it back together? I found the new pushrod on mine wasnt threaded as far as the oringinal and i had to raise the pedal height to get enough freeplay. One of these days i will take it back out and thread the rod a bit further to give my long legs a little more room...( im 6' 4")
Ryan
84 110SW County LHD
07 L322 Vogue
engine, vin
Throttle Position Sensor Source?? rgrrvr Defender Technical Discussions 34 April 10th, 2013 09:56 PM
Throttle Position Sensor (TPS) Duke D90 Wanted 0 April 3rd, 2010 05:15 PM
TPS - Throttle Position Sensor for 1997 D90 #ERR4278 pcscharfe For Sale - Parts 11 August 27th, 2009 02:31 PM
Idle problem - Throttle position sensor? JBfoot Defender Technical Discussions 20 January 7th, 2008 11:45 AM
Throttle position sensor chrisvonc Wanted 0 April 24th, 2005 05:57 PM
