Engine rebuild/replace advise needed. - Page 6 - Defender Source
Old April 17th, 2007, 01:46 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Jim did you listen to the vid????
Old April 17th, 2007, 02:10 AM
pendy's Avatar
pendy
jim pendleton
89'd90
No. I will now.
JP
Sounds like low oil pressure even when it is cold. Its doing camage to run it like that. Duh.... Maybe a bad cam bearing or dirty oil circuit causing low oil pressure to the top end. Pulling the pan is a good idea.
It may sound crazy but this is what I would do. Pull the pan. Look for problems. Note any.
Remove the pickup tube from the block. Use an air nozzle to pressurize the oil circuit. Look for the main leak that is causing low oil pressure to the top end. Bad main bearing. Bad Cam bearing, Bad rod bearing etc... If nothing shows up remove the rockers and pressurize to comfirm blockage to the top end. And maybe use cleaning fluids and devices to free up the oil circuit to the top end.
But my bet is an internal oil pressure leak lowering oil pressure to the top end.
JP
Try to save it.
legend in my own mind
Old April 17th, 2007, 03:30 AM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I had some top end noise once - it ended up being a seized lifter. That lifter ground down the lobe on my cam to nearly round, at which point the noise got much worse and it was understandably no longer firing on that particular cylinder.
New cam/lifters fixed it right up. The cam bearings weren't showing any copper.
I have had the misfortune of experiencing nearly everything which can fail on this truck, FYI. I said *nearly*, as I'm still experiencing new and exciting disasters, such as my current maybe-cracked-block-or-slipped-liner dilema.
Old May 15th, 2007, 09:03 PM
I've already decided I don't trust this engine, and it's replacement is in the works (thanks Pendy). But I'd still like to better understand what's wrong with mine. I drilled a hole in the oil pressure sender and tapped a thread to match a oil pressure sender I bought at pep boys. I hooked it up and got the following readings:
Cold: Idles and about 30 psi, went up to about 35psi on the road.
Hot: Idles at about 20 psi (maybe 19), and ran about 30 on the road.
From what I have read here this seems pretty good, although I don't know if these gauges are reliable or need calibrated somehow. Maybe I'll get my friend Loic to try it on his truck as a reference
charles
Old May 24th, 2007, 09:14 AM
Haven't gotten to compare pressure readings with Loic as he's out of town. I suspect the engine is fine and just needs a top end rebuild, but that will be another day or left to someone else. Anyone want to buy a 3.9 long block (will include the timing cover and all)?
Just to close out this thread, the replacement is going to take place on June 2nd.
http://www.defendersource.com/forum/...3831#post93831
charles
ac, engine, rebuild
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Turbo/Supercharger upgrade advise needed babushka99 Defender Technical Discussions 2 October 16th, 2004 08:26 PM
