Engine Overheating Problems - Defender Source
Old July 19th, 2010, 11:09 AM
MUDROVERNC
Michael Wilfong
1994 Land Rover Defender 90
Hello Rovers,
I am having serious engine overheating problems. (newer Radiator, new hoses, new fan belts, new thermostat) Yet the engine red-lines from simple driving. If I start driving and keep going I am okay. Once I stop for traffice etc..the temperture guage climbs and never recovers...Any suggestions would be greatly appreciated.
Michael
Old July 19th, 2010, 11:15 AM
I fixed my by changing the thermostat and topping up the water - some people need to get there's filled under vacuum. The new thermostat may be faulty ... I bought one which is designed to fail open ... risking over cooling rather than over heating.
Also does your fan pass the rolled up newspaper test?
Old July 19th, 2010, 11:27 AM
MUDROVERNC
Michael Wilfong
Overheating
I will try a new thermostat. Someone also told me that once the engine overheats the thermostat may go bad again, which has happend multiple times.
I am wondering fan clutch??
I tried the stick from a lolli-pop which I assume is the same thing as a rolled up newspaper..??
Old July 19th, 2010, 11:38 AM
Not sure a lolli-pop stick is equivalent to the official land rover rolled up news paper ... wouldn't hurt to try.
I checked the level and added water at 3 points - expansion bottle, rad top and the level tube on the top side of the engine ...
You can eliminate the thermostat by running without it ... the engine wouldn't be able to heat up into the red ... that would confirm the thermostat was the issue.
Old July 19th, 2010, 11:41 AM
Which one did you buy?
Old July 19th, 2010, 11:56 AM
the most expensive one in autozone ... about $13
not much use though if your truck isn't running! Did you get the pictures I sent for the ignition switch?
Old July 19th, 2010, 12:06 PM
Yup yup. E-mailed y'all back. Thanks much, Jason.
Last time my truck was running I seem to remember it running hot.
Old July 19th, 2010, 12:12 PM
you've got a good memory! ;-)
Old July 19th, 2010, 03:04 PM
pendy's Avatar
pendy
jim pendleton
89'd90
But one of my clutchless fan setups. I am curious how well it will help your situation. Get the air out of the engine with a good thermostat first though. Have you had the radiator removed and rodded out or cleaned? That is importnant as well.
legend in my own mind
Old July 19th, 2010, 03:18 PM
Fix the problem - THEN buy one of the clutchless fan setups ... otherwise you are just masking the issue ... These engines can run and stay cool ... even in 90F ambient sat for 2 hours while surrounded by cars on the George Washington bridge ... ask my how I know!
Old July 21st, 2010, 02:46 PM
MUDROVERNC
Michael Wilfong
Thank you for all the replies..
First I am going with flushing the radiator..then thermostat..always open..then maybe a fan clutch.
I will let you guys know how it works out!
Take Care,
Michael
defender, defender90, engine, overheating, problems
Experiencing wierd electrical problems, engine power issues? madcowdungbeetle Defender Technical Discussions 0 May 26th, 2008 10:14 PM
Rebuilding a v8 engine - how to fix liner problems robisonservice Defender Technical Discussions 10 August 19th, 2006 10:18 PM
Overheating fun... Trigger Defender Technical Discussions 10 May 16th, 2005 10:04 PM
