Engine Overheating - Defender Source
Old April 2nd, 2014, 09:43 AM
WD90's Avatar
WD90
Dan
1995 NAS Defender 90
Engine Overheating
I'd search, but I'm strapped for time and using an iphone... My engine is overheating and the heater is not working... I've replaced the thermostat, but no luck. What's the next plan of attack? Water pump? Thanks guys!
Old April 2nd, 2014, 09:47 AM
Is the top hose hard of flaccid (I always wanted to use that word on a car forum) once the motor is warmed up? If it's soft, it's the water pump. If it's hard, it's probably the radiator.
Old April 2nd, 2014, 10:12 AM
the new t-stat is functioning properly?
Old April 2nd, 2014, 01:47 PM
WD90's Avatar
WD90
Dan
I'll crank it up when I get home and check the hose... No idea how old the radiator is. I'm assuming original. I bought a new tstat when it first happened and it didn't fix the issue.
Old April 2nd, 2014, 09:33 PM
justmarv
Marv
1997 D90
I am having same problem, but only when sitting in for a long train or in stopped traffic. Just noticed today that my clutch fan is not spinning very fast when at idle, can stop it with my finger! There is never an issue while driving only while stopped. Hope this is the issue for me, maybe someone can comment on this as well?
Old April 2nd, 2014, 09:39 PM
Ray_G's Avatar
Ray_G
Ray Gerber
If you think your fan clutch is dead it's a easy replacement on your 97 for a Hayden 2626. Doesn't give you the C130 effect & is cheap enough to be worth doing amidst troubleshooting.
R-
Ray
Old April 2nd, 2014, 10:02 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
no heat sure sign of low coolant make sure your not air bound ,pull the top plug off radiator and off the heater hose should have steady flow at both if not fill until it comes out of heater hose then cap and repeat at radiator .. try that see what happens
No Mall crawler here
Old April 2nd, 2014, 10:26 PM
pressure test your system ...and fill it up ... if the heater isnt working you don't have enough water in the system.
Old April 3rd, 2014, 05:36 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
There can be a number of issues, but don't overlook the radiator regardless of what else you find. It's almost 20 years old. I bet it needs, at best, to be rodded. Maybe even a recore.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 3rd, 2014, 07:23 AM
New viscous coupling time.
Old April 3rd, 2014, 07:46 AM
this! you have air in the system! quick way to warp a head or blow a head gasket! nest question is where did the coolant go? That's the more important question.
Mark Kellgren
KM4BOR
Old April 3rd, 2014, 12:23 PM
WD90's Avatar
WD90
Dan
I'm a novice at all this, but I'm going to give these a try tomorrow when I get off from work... so I just remove the hose from the heater inlet?
I also still need to check the fan clutch with the rolled up newspaper...
I'll check the fan clutch and pressure and see if those may be the case, and I guess this would potentially be the issue otherwise.
This scares me, because I had to drive her home (about two miles) in the red... she was stuttering last time I cranked her up, but she had also been sitting for a month.
Old April 3rd, 2014, 01:17 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
The crazy thing about cooling problems is it's probably some combination of all the above.
If you can stop the fan, new viscous clutch.
Laser temp your radiator to check temp difference from top to bottom. I can't remember how much it should be but it's on the board.
Is your water pump weeping fluid? SUPPOSED to weep fluid if it's going out.
There is a test for blow head gaskets too... I think it's bubbles in the overflow tank. But not positive.
And one STUPID thing that got me... I ordered a new radiator cap for the overflow tank. That system is pressurized. Although the place said it was "genuine" it didn't fit tight. Make sure that cap is tight and properly pressurizing the system.
Make sure you are filling the coolant up properly.
Old April 3rd, 2014, 06:10 PM
I really like the rrc fan and clutch, moves significantly more air than the stock defender fan
Old April 3rd, 2014, 07:33 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
http://www.youtube.com/playlist?list...7gVsWBOmpcJGSq
These videos helped me out a lot (as did the forum) when I was having issues with mine. For me it was a bad ground and a bad gauge, no actual overheating. Get a laser temp gun and see if the engine is actually overheating.
Old April 3rd, 2014, 08:06 PM
andyrad
Andy Radlgruber
None.
It all starts with one problem and then turns into a multitude of them. A bad fan clutch will lead to a mild overheat which blows off some coolant which creates an air pocket which creates an even bigger overheat and a warped head, coolant (if there is enough left) into the cylinders and a blown engine. Speaking from experience up to the blown engine as there was not enough coolant left, but a warped head was the result.
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old April 3rd, 2014, 08:42 PM
You really dont want to know how hot it is, the infrared temp gun and VDO gauges were the worst thing Ive ever done.
If the Rover gauge says its hot, its HOT
Old April 3rd, 2014, 09:27 PM
aaronlam's Avatar
aaronlam
aaron lam
I got rid of the VDO and went back to stock too but I also have a Scangauge since I have a 97. The rover gauge doesn't move from tick left of center from 179-210 on the Scangauge. I haven't been over 210.
Old April 3rd, 2014, 10:48 PM
RoverDude
John Gadd
Many
Is that what ended up being the issue?
-Jeff
He drove it 2 miles in the red. Now it stutters. Regardless of what "was" causing it, you can bet he needs at least a head gasket job.
Old April 4th, 2014, 08:11 AM
WD90's Avatar
WD90
Dan
I took the plastic cap off from the top of the radiator yesterday and topped the water off. Started the engine and it was purring like a kitten. Could there still be head gasket damage in that case? I rolled up a newspaper and was able to stop the fan, so that means water pump isn't up to par right? I also noticed a hairline crack in the plastic hose connection on top of the heater core. At least I know the radiator is ok.
engine, overheating
Engine Overheating Problems MUDROVERNC Defender Technical Discussions 10 July 21st, 2010 02:46 PM
110 tried almost everything and it is still overheating.need some advice draaronr Defender Technical Discussions 21 November 17th, 2004 07:25 AM
Overheating Question Troys Defender Technical Discussions 8 August 11th, 2004 11:04 PM
overheating issue--viscous fan Davis Defender Technical Discussions 5 August 4th, 2004 12:11 PM
overheating- what should i check? MiniGuy Defender Technical Discussions 13 November 21st, 2003 08:13 AM
