Engine Oil Filler Cap - Defender Source
Old November 15th, 2014, 11:23 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Occasionally when I need to top off my engine oil, I can barely unscrew filler cap. It somehow gets so tight that more than once when I have unscrewed the cap, the oil filler neck/funnel comes unscrewed from the valve cover also! Has anyone else had this issue? The cap is plastic so I'm wondering if I just need to replace it and if I need to maybe apply some locktight or something to the filler neck so it doesn't come unscrewed from the valve cover.
Old November 15th, 2014, 11:42 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I think everyone has had that issue. I don't know how others deal with it. I just find it to be a minor annoyance that I tolerate and move on.
Black Rhino Lives Matter
Old November 17th, 2014, 10:42 AM
carlosz's Avatar
carlosz
Carlos
there is an "o" ring the bottom of the filler tube matching the valve cover... replace that.
Old November 20th, 2014, 12:50 AM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
thanks I'll see if I can get that o-ring
guess the cap is probably ok?
Old November 20th, 2014, 07:22 PM
carlosz's Avatar
carlosz
Carlos
It's a land rover, Murphys laws apply, check the cap too....
the truck ran like a "raped ape"
A fussy warm weather creature...
engine
200tdi Fuel Filler Cap Part Number needed sonoronos Defender Technical Discussions 14 November 1st, 2013 03:49 PM
Transfer Box oil filler mod jhhorse Defender Technical Discussions 5 December 9th, 2010 05:47 PM
Fuel filler/cap difference? MUDSUX Defender Technical Discussions 5 July 6th, 2010 11:15 AM
Oil Filler Neck unscrewed... specops1526 Defender Technical Discussions 6 April 5th, 2009 11:55 AM
diesel leaking from filler cap artm Defender Technical Discussions 2 December 4th, 2004 05:59 PM
