Engine mounts - Defender Source
Old September 20th, 2006, 07:59 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Engine mounts
What is the best way to tell if the engine mounts (300 tdi) are going bad? I have a funny yet annoying vibration only when under load that does not seem to be any of the normal culpirits.
also any one have any first hand experience with the QT heavy duty mounts?
Old September 20th, 2006, 08:14 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Pull the bonnet and see of the engine jumps when revving excessively.
Although this kind of assumes you know how much the engine moves when the mounts are known to be good. Which is more than you might imagine.
Old September 20th, 2006, 08:28 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
put a block of wood under the sump and jack the engine, if the truck lifts its ok, if the engine pops off the mounts its the mounts
3rd low and BOOT IT
Old September 20th, 2006, 09:06 PM
D90user's Avatar
D90user
steve
I like that one jimmy... I'll give it a shot.
Hard to tell with the revving bit... tried that but with the diesel itls moves like hell anyway.
Old September 20th, 2006, 09:07 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
thats what i did with mine and the mounts came apart
3rd low and BOOT IT
engine, mount
QT Services Diff Guards and HD Engine Mounts JohnC The Vendors Loft 1 February 16th, 2006 09:53 PM
Engine Mounts david_jackson Defender Technical Discussions 1 February 8th, 2006 06:48 PM
Installing engine mounts Doug Defender Technical Discussions 4 February 23rd, 2005 06:49 PM
90 main wiring harness & TDI engine mounts TDI Guy For Sale - Parts 5 December 13th, 2004 01:45 PM
