engine miss, severe on acceleration - Defender Source
Old October 31st, 2014, 03:41 PM
doscazadores
Vic Stull
none
'95 D90, manual trans. 70,000+ miles. Running fine until roughly 3-4 weeks post head gasket replacement to address coolant leak. Don't see how it would relate to my current issue but thought I should mention it.
On acceleration the engine misses noticeably. Unburned fuel builds up and numerous backfires, but very muted, occur. Less pressure on the gas pedal helps reduce the problem. Once I get to about 2000-2200 rpm and in 3rd gear it settles down and is bearable or even disappears. On flat ground not needing to jam it for additional mph it seems to run fine.
Checked plug wires, all plugs, rotor, and all appeared o.k.
Should mention also that the problem cured itself for a couple weeks when I was driving it more, then came back with apparent intent to make up for lost irritation and frustration. There have been afternoons when it's run well also. It's nowhere near a daily driver and never had this problem before in the 2 years that I've owned it during which time I don't think I put on less than 2,000 miles.
Any ideas what might be going on other than demon possession? I think I need an intervention here.
Thanks for any thoughts. Vic
Old October 31st, 2014, 04:11 PM
Timing and or vacuum advance.
Old October 31st, 2014, 08:05 PM
carlosz's Avatar
carlosz
Carlos
Vehicle speed sensor on side of the case.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old October 31st, 2014, 08:17 PM
Lucas dizzy and all REALLY HATES any amount of moisture. Coolant, water whatever if it gets in the diz ir on the cap or in the ignition module it will give you fits. Be sure evrything is dry.
Old October 31st, 2014, 11:15 PM
Cracked distributor cap, bad TPS? Any check engine light?
Old November 6th, 2014, 03:52 PM
doscazadores
Vic Stull
none
Thanks, everyone, for the help. o2batsea was pretty close to the root cause. Little corrosion on the inside of the distributor cap so not good elec contact from there to the rotor. New distributor cap, rotor and, to be safe, new plug wires. Runs like crazy now. I'm a happy guy again.
ac, engine
A Severe Lack of Emoticons bigrichmanitoba Misc. Chit-Chat 25 January 23rd, 2014 02:17 PM
High rpm miss when hot evilfij Defender Technical Discussions 10 November 15th, 2011 12:33 PM
Near Miss in Delaware steinhnj Misc. Chit-Chat 1 June 15th, 2009 10:01 PM
HS2.8TGV Severe power loss. Air in fuel line? DesertRat Defender Technical Discussions 12 February 24th, 2007 08:35 AM
Severe frame rust! Bowtracer Defender Technical Discussions 15 March 31st, 2005 02:18 PM
