Engine loses power at 2500 rpms - Defender Source
Old August 15th, 2010, 04:11 PM
Hazard's Avatar
Hazard
David Hazard
95 D-90
So I think this is a fuel pump issue but wanted to check here first.
When driving the defender, when I reach 2500 RPMs, the motor starts to bogg down and choke out very badly. It wont be able to go any higher in RPMs till I shift to the next gear which is fine till I reach 2500 RPMs again. Ive had this problem in my older jeeps and it always seems to be a fuel filter or fuel pump issue.
The only other thing I can think of is, I replaced the headlight switch and removed the steering column cover and Im wondering if I hit a wire or something in there? It wasnt doing that prior to the replacement.
Thoughts?
95 D-90 3" lift, 35" Baja claws, salisbury rear axle, 4.88 gears, lockers, winch, etc
Old August 15th, 2010, 06:38 PM
jack SF
jack baran
95 ST yellow
Check fuel pressure and volume or just replace fuel filter.
Check wire, plugs, cap and rotor.
Replace ignition module.
Than once I had an alternator causing inerferance exactly at 2500rpm and car would not accelerate thru that.
Old August 15th, 2010, 09:11 PM
crobinson
Chris Robinson
97' D1
Could be the speed sensor under the drivers seat, along the frame rail.
Old August 15th, 2010, 10:56 PM
If it's not fuel ... it could be air ... every 'fuel' problem I've had has been air related ... check the plenum pipes.
Old August 17th, 2010, 08:31 AM
Hazard's Avatar
Hazard
David Hazard
95 D-90
Go on...
What is this speed sensor you speak of?
Old September 3rd, 2010, 10:23 AM
Hazard's Avatar
Hazard
David Hazard
95 D-90
Any other help on this guys? Still happening.
I drove it all week with no issues, ran perfect. Then yesterday, it wouldn't climb above 2500 Rpms again. Very intermittent problem. Like is said this whole problem started after I replaced the headlight switch in the steering column. Is there anything that I could have affected in there?
Old September 3rd, 2010, 02:12 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I'd second the alternator suggestion. Get a new one like Ron said, NOT REBUILT FROM AUTOZONE. I had the exact same problem, it was the alternator, BP has like new ones for like 200 something. Good luck.
Robert Deniro
Old September 3rd, 2010, 02:42 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Another look!
Get the problem to start happening consistant and then pull the belt for the alt. or if serp driven then take the belt off and drive around the block and see if the problem goes away....if still there then it's not the alt! The TPS can get a flat spot in it and cause similar issues. Back-probe the TPS with 2nd ignition on and check the scaling of it. It should rise from almost zero up to around 5 volts at wide open.
Old September 3rd, 2010, 08:39 PM
mattwhite
Matt White
94 D-90
I had the exact same problem after taking my 90 for a swim. When I say "swim" the bottom seat cushions began to float.
I my quest to find the problem i messed with a bunch of things, but I'm 99% sure that it was a little water in a connector going to the MAF sensor. It wasn't the main MAF connector b/c that was the first thing I checked, but on a 94 at least, there is a little plastic connector just downstream from the main one. It had water in it, I cleaned it out and it has ran fine since.
Matt
Old September 17th, 2010, 06:34 PM
Hazard's Avatar
Hazard
David Hazard
95 D-90
So here's the latest on this. I noticed when I turn on my headlights or blower motor (heater) the engine starts doing this. When I turn them off it runs fine?! Is this an alternator issue, or a wiring issue in the steering column?
Anyone had experience with this?
Old September 17th, 2010, 08:35 PM
Chris Vitale's Avatar
Chris Vitale
'95 D90 ST 2.8L TDi #2050
Bad diod in the alternator. I had the same problem. New alternator fixed the problem.
Good luck.
Old September 17th, 2010, 08:44 PM
Hazard's Avatar
Hazard
David Hazard
95 D-90
Good luck.
OK, thats 3 suggestions on the alternator. Im going to try unhooking it tomorrow (after the Buckeyes win of course) and seeing if thats the fix.
Old September 18th, 2010, 08:56 AM
kenny kustom
ken bryant
none
Will it rev past 2500 in neutral ?
Old September 18th, 2010, 01:12 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Mine was the alternator. One of the zenier diodes had falled making the rectifier produce some A/C current which makes the coil misfire. For me it was at 2300 RPM, any gear.
Old September 18th, 2010, 01:29 PM
Hazard's Avatar
Hazard
David Hazard
95 D-90
Yes it will. No problem in neutral only under load
Old October 15th, 2010, 02:23 PM
Hazard's Avatar
Hazard
David Hazard
95 D-90
Installed the new alternator and that fixed it!!!! Thanks for the advice everyone!
Old October 15th, 2010, 03:58 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
good to hear
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old October 15th, 2010, 04:57 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Gawd I like antique Diesels.....
Keith
Big, Red and ... aaa Red..
engine
Engine sweet spot and highway RPMs cgalpin Defender Technical Discussions 32 December 30th, 2009 12:02 PM
Experiencing wierd electrical problems, engine power issues? madcowdungbeetle Defender Technical Discussions 0 May 26th, 2008 10:14 PM
