Engine light on...but no code. - Defender Source
Old November 17th, 2012, 06:47 PM
sro
Sam Odio
2008 LR2
Recently I was descending a steep slope with large rocks (causing a lot of shaking and jostling) and the engine light came on. I immediately pulled over to check the code and there was none. Later, after filling up, it went off.
Now the engine light seems to come on and off at random intervals...sometimes when the truck is shaking (eg going over rough terrain).
Any ideas? No fault codes so I'm completely lost.
Old November 17th, 2012, 08:17 PM
The ECU can throw codes that don't come up on the display. Sometimes these are just random errors ... I'd clean your connections, check your grounds and if that doesn't stop it try a rover gauge to read the code.
engine, ht
Check Engine light Question? True or False? Hammertime Defender Technical Discussions 0 April 5th, 2009 10:39 PM
Service Engine Light bjf Defender Technical Discussions 8 July 30th, 2008 02:14 PM
Replaced passenger cat and now I get check engine light shawnpalmer Defender Technical Discussions 35 July 17th, 2008 10:14 AM
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
